chris parkin Posted July 6, 2016 Posted July 6, 2016 Evening all, I've had a quick measure from the dims available online and the two seem to share the same overall dimensions. My question is, are the bottom location and top clips in the same position? I have a 2.0 blacktop that currently has a px600, so would a jc50 go straight on? (Assuming inside depth and hood cut out are appropriate) Tar muchly! Quote
Nic Chase (NICO) - Shropshire & Mid-Wales AO Posted July 9, 2016 Posted July 9, 2016 The top fixings are the same on both. The Pipercross backplate can be modified to fit the ITG filter by removing material on the bottom. But not vice versa. This is what I did on mine to fit an ITG filter. Quote
chris parkin Posted July 9, 2016 Author Posted July 9, 2016 The top fixings are the same on both. The Pipercross backplate can be modified to fit the ITG filter by removing material on the bottom. But not vice versa. This is what I did on mine to fit an ITG filter. Thanks for that, much appreciated. I'm the same as you, moving to the ITG from pipercross. Quote
