Recovering deleted video from GoPro.
Hi all,
Can anyone recommend a free method to restore a deleted file from my memory card? I accidentally deleted the file (2Gb) and I want to restore it, searching the web it's all about expensive software to do the job - is there no free method anyone is aware of?
Thank-you in advance.
Steve.
Thanks Geoff, in this instance the file has been deleted. I can't even see it. I cursed myself when I did it and took the memory card out straight away to prevent losing completely. Now I am stuck...
AdamR may be the man to speak too.
I have a Mac computer and I used an App called CardRaider
http://www.ecamm.com/mac/cardraider/
It costs $19.95. but you get a chance to use it for free before you buy it.
I used it to recover a lot of photos I deleted and they were recovered without a problem
As long as you haven't over-written the data (and if you've pulled the card out you won't have) there's a good chance of recovery with any decent "undelete" tool.
there are lots to choose from and most free to try.
As the go-pro uses standard Micro SD cards you should be fine.
If however you've formatted the card (as the go-pro tends to do under "delete / format all) then you may strugle (as formatting has the same effect on the old data as over-writing does).
Whether you pay for an undelete tool really depends on how much you want the video back
Thanks All. I've found the file using a tool, now I just need to stop being tight and splash the cash to retrieve it. Thanks. Steve.
