10 litre Sprint/Hillclimb Fuel Tank manufactured by AliFab. Top quality item, dimensions in drawing below. First 3 photos are when it was newly fitted to my car. Last 3 are now, and as you can see it's still in perfect condition.
130mm square sump to avoid fuel starvation.
Sight tube fitted diagonally on side to check fuel level.
50mm filler and screw cap.
Bolts into standard SEiW chassis using 4 bolts through the mounting flanges.
Takes standard VDO fuel sender through 43mm hole, as fitted to standard Westfield tank, 5 ali rivnuts fitted.
10mm feed pipe
10mm breather pipe
-6 JIC return pipe
Selling because I'm no longer competing and have switched back to a standard tank.
£75 + P&P (estimated £15)
Fuel%20tank%2010L%20Fraser%20Bell_zpsswt
pm on the way
Now sold, thanks
