SootySport Posted May 30, 2016 Posted May 30, 2016 Any one have one kicking about? Mines cracked at the base again Please PM me
iowlee Posted May 30, 2016 Posted May 30, 2016 I have one if you are desperate , however too far to collect I guess so will need to be posted. How do you crack them? Lee
SootySport Posted May 30, 2016 Author Posted May 30, 2016 Thanks for the offer Lee, think I'll try a local welder first and see if it's fixable. If not, I'll message you later this week. The original alloy one was leaking when I bought the car and the replacement all steel one has cracked 1/4" from the mounting plate. Reckon they get cracked by constant removal and re fitting of the cam cover, the rubber breather pipe needs a bit of wiggling to get a good seal on the cam cover connector. 1
tisme Posted June 1, 2016 Posted June 1, 2016 Try a silicone hose rather than rubber - they're far more flexible https://www.amazon.co.uk/Vauxhall-Corsa-C20LET-Breather-Silicone/dp/B00NO00QAM
SootySport Posted June 1, 2016 Author Posted June 1, 2016 Try a silicone hose rather than rubber - they're far more flexible https://www.amazon.co.uk/Vauxhall-Corsa-C20LET-Breather-Silicone/dp/B00NO00QAM I was looking at them, think I'll order one. Had the tube welded up in the end at my favourite welding shop, he's done a nice job of it. 1
