Out of curiosity while out today I called in at a weighbridge close by to see what my car weighed. I was pleasantly surprised to find it weighed 560KG I was expecting around 750KG.
It is a 2001 SEW , 1600 xflow, live rear axle, aeroscreen , half doors, no spare, and tools etc taken out.
I now have a mission to 'add lightness'  first step may be the large Halfrauds 30ah battery, I cant see me getting down to FW levels as it gets a bit expensive with alloy calipers, uprights hubs etc.  If I used it on the track it may be different , at the moment the car is fast enough for me.
Name Car / Car & Driver
Alex 531.0 / 620.5 (Narrow, 1.6 4AGE, aeroscreen)
Pete 556.0 / 638.5 (Narrow, 1.6 VX, screen )
Kevin 570.5 668.5 (Wide, 2.0 Zetec, aeroscreen)
Marcus 573.0 / 650.5 (Wide, 1.6 Mazda, aeroscreen)
Chris 575.5 / 676.5 (Narrow, 2.0 VX, aeroscreen + Cage )
Mark 592.0 / 656.0 (Wide, 1.6 Mazda, screen)
Tim 595.0 / 687.0 (Wide, 1.6 Sigma, screen)
Bernie 595.5 / 693.0 (Wide, 2.0 VX, screen)
Andy 597.0 / 681.0 (Wide, 2.0 Zetec, aeroscreen)
Graham 601.0 / 702.0 (Wide, 1.6 X-Flow, aeroscreen)
Dave 609.5 / 684.5 (Wide, 1.8 Mazda, aeroscreen)
Mike 621.5 / 710.5 (Wide, 2.0 Zetec, screen)
Stuart 636.0 / 723.0 (Wide, 2.0 Zetec, aeroscreen)
............ Its the later wide models with the zetecs that break the scales  :getmecoat:  :getmecoat:
Sure is....... 625kg of Lardiness (without me :down:  )
Interesting stuff, looks like I will never make 400KG but 540 may be achievable, could remove the passenger seat, and perhaps the runners on the drivers, the RAC roll bar must weigh a bit I would prefer the standard Westfield 50mm bar. This could get addictive!
A lithium ion battery can be well under 1kg, loads of weight to be saved there.
A lightweight billet flywheel will also save you bare KGs and the car will rev more quickly.
I would guess mine around the 600 mark without me in it and probably about 2T with me in cos I'm now a fat pie. :)
Mines 511kg full of fuel
496.6kg with 30% full tank... add 79.3 for me with helmet :)
Really heavy parts on your spec are going to be a) engine b) gearbox c) rear axle
It's amazing just how much a Type 9 / 2000e gearbox weighs for example - also check what material the bellhousing is made of (magnets come in handy here)  :)
You could change just about all of the above for alloy based items but it's obviously a cost/hassle/availability/upgrade-itus decision ???
Do you use 30% so you can tell yourself it's under 500kgs? :p
So with 30% fuel that would have mine about 495 with a cage ;-)
^ then I get in and completely ruin it lol
Haha I have the same problem!
Mines 528kgs - I need more carbon to get down to your car weight :d
