1959grantura Posted May 10, 2016 Posted May 10, 2016 So it looks like from MIRA at the weekend I am suffering with the dreaded standard tank long left hand turn fuel surge issue , So I am looking for the best easiest and cost effective solution. -Usage is local blats, Trackdays and select sprints/Hillclimbs -I will shortly be having a trailer so no longer be driving to and from events of distance So far the options look like -Swirl pot with another pump (Expense? ) -Demon tweeks baffle inserts into the current tank (Anyone tried this? does it work?) -Smaller purpose tank foam and baffled Interested in what other people have done with costs etc? Many thanks Quote
TableLeg Posted May 10, 2016 Posted May 10, 2016 Just to throw it into the mix there's the Motorsport collector pot. https://store.034motorsport.com/fully-enclosed-fp34-fuel-pump-surge-tank-for-bosch-044-motorsport-fuel-pump.html Quote
CosKev Posted May 10, 2016 Posted May 10, 2016 Probably the cheapest and easiest job will be to get a sump added to your tank along with either some baffles or tank foam. Have you got room for a sump to be added to the bottom of your tank? Quote
CosKev Posted May 10, 2016 Posted May 10, 2016 If you do fancy modifying your tank speak to Rich,excellent quality and very well priced. He will modify/make it to your specs http://www.ebay.co.uk/itm/ALLOY-1-5-LTR-FUEL-SWIRL-POT-WITH-8mm-FITTINGS-KIT-CAR-RACE-RALLY-/231923553713?hash=item35ffb895b1:g:yZkAAOSwKfVXHR~P Quote
pete g Posted May 10, 2016 Posted May 10, 2016 I just remembered I have a sei wide bodied tank that I had modified with tank underneath which sits between the rails . worked fine on my car for sprints. you can try it and see if any good .if you wish .and either buy off me or get yours done the same if ok . [modified for injection ] and has fuel level gauge 1 Quote
1959grantura Posted May 10, 2016 Author Posted May 10, 2016 Pete that sounds fantastic !! I had a look at mine it does have a small bowl in the left side but pretty shallow. Any chance of bringing it to palace Pete pretty please? Quote
pete g Posted May 10, 2016 Posted May 10, 2016 yes mine has about 2 ltr sump in the center and center take off for dash 8 fitting my memory not what it was please remind me day before Quote
B.RAD Posted May 15, 2016 Posted May 15, 2016 Sounds like a great solution there Dave! Did you get the breather sorted? Also try the foam blocks I mentioned to you, I think Martin (marto303) still has a box of them - I'm sure he'd be happy to sell you a few at the next event. They made a big difference to my tank, I can now run it with just a few litres vs half a tank previously. Quote
1959grantura Posted May 15, 2016 Author Posted May 15, 2016 Car is back in a million pieces Barney ...Have fitted a quick shift ...Seemed like an easy job to start with but left a few cosmetic issues to iron out. Breather will be next once its back together , Merlin motorsport look to have plenty of options so will nip over there with the car at least I will know the new valve will fit and will be drilling a hole top of the filler. (To be honest I have only got Crystal Palace then hopefully Pete`s tank will sort it all out) Quote
