Synchrometer
Has anyone got Synchro meter for itb's that I could borrow or buy.
Or recommend somewhere to buy one.
Andy
Andy
I picked one up at Stoneleigh from Northampton Motor Sports for £40
I am still using mine as I need to sort my emissions out with the ECU, I am waiting for a USB/serial port adaptor from Omex
They are the same thing Andy, they just measure air draw through the port. You only need that for balancing the airflow.The throttle butterflies should be shut closed and there is an air bleed which you adjust to set the flow up the same across the throttles. I guess Dave is trying the lean out his idle mixtures. I would also reset the throttle potentiometer before adjusting and fueling.
Thanks now ordered one!
