AndyD-Yellow Peril Posted April 22, 2016 Posted April 22, 2016 My winter project - gearbox swap....so out with the Mitchell Cotts and in goes a catering van 6 speed So looking for a few parts! Type 9 propshaft Mounting plate type 9 to chassis, bolt in type Gearbox mounting isolator if new or excellent condition Now the big ask... bell housing for long input shaft ... Duratec to type 9 ... as i have been told my Mitchell Cotts bell housing is unlikely to work (suits a short input shaft) .... unless anyone can tell me any different! I'm heading to Stoneleigh Sunday 1 May, so could be a good work out? What have you got? Andy 07729 847945
JulianE Posted April 25, 2016 Posted April 25, 2016 I have a four bolt steel mounting plate if that's what you are looking for and a new heavy duty type 9 lower mount , I will be going to Stoneleigh on the Sunday too
AndyD-Yellow Peril Posted April 25, 2016 Author Posted April 25, 2016 Great, will be at Stoneleigh on Sunday. Let me know if that's an option Thanks Andy 1
AndyD-Yellow Peril Posted April 29, 2016 Author Posted April 29, 2016 Bttt Still on look out for ..... ....type 9 prop shaft .....Type 9 gear lever extension Can collect on Sunday at Stoneleigh Andy 07729 847945
drummerdrum_uk Posted April 30, 2016 Posted April 30, 2016 I have just posted a Type 9 to english axle prop if thats any good. I also have a bellhousing which came of a 6 speed Caterham box so believe its the same a long input. I can bring on sunday if you want to have a look?
stephenh Posted April 30, 2016 Posted April 30, 2016 I think from memory that you are correct, Greenstreak, that the Raceline bellhousing is for the standard (short) input shaft.
AndyD-Yellow Peril Posted April 30, 2016 Author Posted April 30, 2016 Sure, if you can bring to Stoneleigh TBH, i am not sure if i need the bell housing, as mine currently is, i believe a Racine one, which may fit ok. If you can bring with you so i can measure up? Prop - sounds perfect, guess it mounts to a sierra diff ok? i will take it Andy
