Motorhome levelling ramps
Getting my new Motorhome on 3rd May and just wondered what make and length of levelling ramps you use . I presume you just need 2
?????????????:t-up:
Terry
I bought some on ebay that came with a bag to put them in.
From memory they were cheap
David
edit to add these
http://www.ebay.co.uk/itm/171956034892
Thanks david
I have ordered them :yes:
I've a couple of fiamma ones for my campervan. Cheep enough.
Just use your wallet Terry
He's from Yorkshire, these things are a delicate procedure, can't just rush into opening it!
Caravan/Motor home leveling ramps are also useful for the westi, I had a couple from my caravaning days and purchased a couple more so that if I needed a little more ground clearance but did not want to lift it on to stands I could drive it on to the 4 ramp.
Like most Yorksiremen I have short arms and deep pockets so I cant always reach my wad :laugh:
On good sites you only need a pair really. On some less than good you sometimes need more, to level front to rear and side to side. I just use wood of differing thickness and have a level which is marked so I know how much to add and where.
