Duffy Posted January 30, 2003 Posted January 30, 2003 Vauxhall 2.0l xe crank needs to be re-ground £40 Vauxhall standard con rods £30 Hardtop and doors etc £110 Standard uprights £30 Big standard lamps, broken glass. £15 2.0 vauxhall 16v XE carb kit. Pair 48 Dellorto carbs, good condition with inlet manifold. Throttle cable and all brackets. Fuel regulator. Fuel pump, red top. MBE967I ECU Full MBE loom for system to run, with taco output and gearshift output. Throttle potentiometer kit. Distributer less coil pack Pistons with correct +2mm pockets. Will also find orignal fitting instruction. If this kit is used with a set of new cams, valve springs and titanium caps will give u a very reliable 200+ bhp, or with few more internals(pistons etc) can go over 220bhp.(I had 225bhp with this kit) open to offers on this kit. Its no use to me now Give me a call 07703 187257 01306 627103 Duffy@vauxhalltec.freeserve.co.uk
dasamdy Posted February 1, 2003 Posted February 1, 2003 would you consider splitting the carb setup?? I'd be interested in the ecu, coil pack & other bits n bobs Dave
