2.0 vauxhall 16v XE carb kit.
Pair 48 Dellorto carbs, good condition with inlet manifold.
Throttle cable and all brackets.
Fuel regulator.
Fuel pump, red top.
MBE967I    ECU
Full MBE loom for system to run, with taco output and gearshift output.
Throttle potentiometer kit.
Distributer less coil pack
Pistons with correct +2mm pockets.
Will also find orignal fitting instruction.
If this kit is used with a set of new cams, valve springs and titanium caps will give u a
very reliable 200+ bhp, or with few more internals(pistons etc) can go over 220bhp.(I had 225bhp with this kit)
Total £800
Give me a call
07703 187257
01306 627103
Duffy@vauxhalltec.freeserve.co.uk
