KugaWestie Posted March 31, 2016 Posted March 31, 2016 Removed from my Mazda SDV Only 6500 miles of use over 4 years They work perfectly well, no leaks! In need of a clean up though. Fronts Rears Nearly £450 new from Westfield http://parts-shop.westfield-sportscars.co.uk/front-suspension?product_id=114 How about £150? WSCC courier service or can take to Stoneleigh
Jibberingloon Posted April 1, 2016 Posted April 1, 2016 Gary, would these be better than the Spax I got last year from the WSCC Courier Service? Whats the spring rate and rough ride height.... mine is the 1.6CVH Wide Body PS sorry haven't been to the meet recently..... fooking work work work Might take them depending on the answer! (1st dibs....)
KugaWestie Posted April 1, 2016 Author Posted April 1, 2016 I think they might be better, but I don't know much about the ones you bought. The set up sheet that westfield provide states that the front springs should be 300lbs and 8" in length and the rears should be 195lbs and 9" in length. To be honest I don't know if the poundages are what they are though! My ride height was pretty standard with them fitted. Approx 145mm front and 160mm rear
Jibberingloon Posted April 1, 2016 Posted April 1, 2016 Let me check a couple of things and will get back to you by Sunday Thx
KugaWestie Posted April 19, 2016 Author Posted April 19, 2016 BTT These will be coming to Stoneleigh and going in the autojumble
