Yanto Posted March 25, 2016 Posted March 25, 2016 Unused SIERRA fitting and suitable for up to 10 8mm discs although the spacers can be changed, available from Hi-Spec for wider discs, I have pins. Not suitable for IVA due to handbrake actuating on pistons. ETA I have a pair of lightly used solid drilled discs that I can send, if required I would like a contribution to the Parcel Force postage rates. Looking for £175 inc postage. http:// http:// http:// http:// http:// Cheers Ian 1
Mike Rowland - Essex AO Posted April 2, 2016 Posted April 2, 2016 Hi, I'm interested - if I can find a way to fit to my '96 seiw sierra uprights. Anyone know if this is possible with a new handbrake cable?
6carjon Posted April 2, 2016 Posted April 2, 2016 You probably can ! Hi spec made me a handbrake cable with the right ends to fit their calipers .I bought some thick aluminium to use as adaptor brackets and had them machined for fit. Your only challenge will be clearance and overlap with existing uprights. You are best to check measurements and make a cardboard template first. My only problem was if the mounting holes were similar to your existing calipers as you don't get any material or space to work with. If you can't get aluminium easily then rally design used to sell adaptor brackets you could machine down. https://www.google.co.uk/search?q=rally+design+caliper+adapter&safe=off&client=tablet-android-samsung&biw=1024&bih=768&tbm=isch&source=lnms&sa=X&ved=0ahUKEwivtKjizu_LAhVJPRQKHXbKBksQ_AUItAEoAQ#imgrc=eScyGHi8KLMaMM%3A Use cardboard it will save you pounds in wrong decisions ☺ 1
pete g Posted April 2, 2016 Posted April 2, 2016 have these on my sprint westfield . std sierra cable fits. if your uprights are for golf calipers then should be a straight swap over I have some sierra fitting ones in my garage if you want to take a closer look mike
Yanto Posted April 2, 2016 Author Posted April 2, 2016 Hi, I'm interested - if I can find a way to fit to my '96 seiw sierra uprights. Anyone know if this is possible with a new handbrake cable? Hi Mike, I will measure the actual bolt spacing which will give you a better idea for fitment if that helps? Ian
Mike Rowland - Essex AO Posted April 24, 2016 Posted April 24, 2016 sorry, I should have replied to say that the pad will overhang the disc with my sierra upright, so better suited to the Golf one (as advertised )
Yanto Posted April 24, 2016 Author Posted April 24, 2016 are they still available ? They are; I will be wrapping and boxing them up to take to Stoneleigh for the auto jumble. Cheers Ian
Yanto Posted October 25, 2016 Author Posted October 25, 2016 I'm bumping these as I have found out by trial fitting on my car with Sierra callipers that they are in fact SIERRA fitment not Golf as I originally advertised them as. Included are a set of Pagid DS3000 pads with the pad cut down to ensure the dreaded HiSpec piston off centredness does not cause uneven pad pressure and wear. £175 delivered. Cheers Ian
