Olliebeak Posted March 18, 2016 Posted March 18, 2016 Looking for a crash pad and two sill covers for my SEW, any colour will do . Someone did message me some time ago saying they had some dark blue ones in the back of his garage but I cannot remember who it was. Thanks for looking
Dave Eastwood (Gadgetman) Posted March 19, 2016 Posted March 19, 2016 Just be aware that an earlier "kit" bodywork crash pad and later ZK bodywork crash pads are quite different to each other. A Kit bodywork crash pad is much deeper front to back, it reaches all the way to the base of the screen, it also only reaches down the scuttle sides part way - it ends more or less level with the bottom of the cast screen uprights. Most significantly though, it's around 19mm narrower at the top than a ZK scuttle, so without widening, doesn't fit at all well. Conversely, the ZK crash pad is quite narrow, only two or three inches wide, it's almost a long strip, rather than the triangular shape of the Kit version - viewed form the side. It reaches all the way round the scuttle, finishing at the join line between scuttle and the tub, either side. It's about 19mm too wide to fit the top of a kit scuttle properly, and might struggle to clear the moulded in "rolled" edge of the kit scuttle.
Olliebeak Posted March 19, 2016 Author Posted March 19, 2016 Thanks for the info, I was looking for the 'kit' crash pad. Seen the sill covers on eBay.
