John Loudon - Sponsorship Liaison Posted November 22, 2002 Posted November 22, 2002 X/F oil cooler sandwich plate, oil cooler and pipes - £40 Aluminium 4 gallon foam filled competition fuel tank - £50 Standard X/F crank, rods and flywheel - £30 X/F steel rocker assembly comprising steel posts, shaft and spacers - £30 (available soon) AP Racing uprated 7.5" organic X/F clutch plate - £20 (limited use) X/F Thermostat housing with filler cap - £10 X/F starter motor - £10 X/F mecahnical fuel pump - £10 (nearly new) Lots of X/F gaskets (residue of 4 complete sets less sump gaskets) - £10 Near new custom made tonneau cover set for narrow bodied SE with RAC roll bar - £150 Pair lightened steel Cortina hubs - £30 Various standard X/F brackets, pulleys, dissy's, pumps etc No sumps or heads Im in Coventry. Buyer collects or pays postage. Contact John on 07971 576848 or email jloudon@usa.net
Paul Hurdsfield - Joint Manchester AO Posted November 22, 2002 Posted November 22, 2002 What size and shape is the fuel tank ? I may be interested.
John Loudon - Sponsorship Liaison Posted November 22, 2002 Author Posted November 22, 2002 Paul, Its oblong and 23" long, 9" high, 7" wide with a screw cap on the top in the middle. It has an 8mm outlet on the end in the middle at the bottom and an 8mm breather at the top above the outlet. John
Paul Hurdsfield - Joint Manchester AO Posted November 22, 2002 Posted November 22, 2002 It sounds pretty much like std westy tank dimensions to me sorry to mess you about but it wont fit a GP Midget Racer I'll just have to keep on looking cheers anyway
crew15uk Posted November 23, 2002 Posted November 23, 2002 May be interested in tonneau cover! Have '92 narrow SE with standard roll bar.. Is there much difference?
YODA Posted November 23, 2002 Posted November 23, 2002 John, Do you have an inline filter for a dry sump system? If so phone me on 07977 423563.
John Loudon - Sponsorship Liaison Posted November 25, 2002 Author Posted November 25, 2002 Yoda, No filter Im afraid. Crew15uk, Ive sent you a PM Regards, John
John Loudon - Sponsorship Liaison Posted December 5, 2002 Author Posted December 5, 2002 Update. All now sold except the following:- Aluminium 4 gallon foam filled competition fuel tank - £50 AP Racing uprated 7.5" organic X/F clutch plate - £20 (limited use) X/F Thermostat housing with filler cap - £10 X/F mecahnical fuel pump - £10 (nearly new) Tonneau cover set for narrow bodied SE with RAC roll bar, near new and custom made. Excellent condition - £150 Pair lightened steel Cortina hubs - £30 X/F steel rocker assembly comprising steel posts, shaft and spacers - £30 (available soon) Regards, John 07971 576848
