drummerdrum_uk Posted February 22, 2016 Share Posted February 22, 2016 Sadly I’m selling my C20XE package off in parts. I had a bolt loosen up in my air box and get sucked in on start up following lunch on my second track day after I had it rebuilt by Steve Milton and upgraded to a dry sump kit. Sadly it has ruined the head and damaged a piston, pushing me to the decision to go turbo route as my next project. These are the individual items for sale: Caterham Carbon Air Filter Cover – designed to reduce induction noise. £250 http://caterhamparts.co.uk/product.php?id_product=2812 Caterham R500 H Box 6 speed and spacer (so you can use a standard type 9 bellhousing) – In Perfect working order £1200 SBD type c Vauxhall XE Manifold – renown to be one of the best manifolds ever made to release power and no longer in production. £500 Custom Wunoff repackable exhaust silencer and straps have only been used on 5 track days. £250 or complete package with Manifold and I will through in a gasket. £700 MBE 9A4 ECU and custom loom from SBD purchased on 05/06/15 so still under warranty. £750 TTV lightweight flywheel like new has done less than 200 miles/2trackdays £125 Uprated clutch Gp1AP plate (200 bhp, high friction material and stronger hub springs) has done 2 track days so still looks like new. £75 SBD 220 Vauxhall 20xe Camshaft (requires pocket pistons) I’ve been very impressed with these. I had them dialled in early with more torque in mind. Made just over 200BHP and 175Ftlb of Torque at Track and Road. £175 Set off Williams C20XE forged conrods with ARP 2000 Bolts. £125 ARP head bolt kit, 2 track days old, therefore like new. £80 ARP main cap bolt kit, 2 track days old, therefore like new. £75 ARP flywheel bolts. 2 track days old, therefore like new £30 Pair of Turbo Sport Vernier pulleys 2 track days old, therefore like new. £100 Set of complete double valve springs. £50 C20xe to type 9 bellhousing. £100 Type 9 Gear lever extension and quick shift gear lever. £50 Set of Mototron/Siemens 690 Injectors + One spare. £150 Complete Type 9 Slave cylinder (Inc Mount, Bearing and 2 different types of spacers.) £100 Complete Dry Sump kit £1750 Pace Dry sump same as SBD low line kit as they make them for SBD Front Cover Mocal Remote oil filter housing Custom Made hoses which have press fittings 5” SBD Cleanable Tank External trigger wheel with alternator, round tooth cambelt pulley and SBD sensor. Sensor is made for the connection on the sump. Rocker cover which has been capped. Will be repainted before shipped. And engine block blanking kit. This complete kit cost well over £2500 and is ready to fit, as long as its fitted on the exhaust side and the tank connects to passengers footwell, the hoses should fit. Again have only been used for 2 track days. Link to comment Share on other sites More sharing options...
