Anyone got or know where to get 3 wire ideally twisted strand cable suitable for a wheel speed sensor?
Need about 3 m
Hi. Already tried them and they didn't have any.
Cat 5 network cable should be fine too. Just pull out or leave the cores you don't need. I'm suprised the cable isn't screen, so I'd keep away from other cables if possible.
If it's for a 5-12V Hall sensor (probably is if 3 core) then any 3 core flex would likely do as those signals are not too prone to noise.
Etb in Southend are a vid stockist and are very helpful - a quick call should have you sorted.
Thanks to all
Got some in the end.
