early morning westy drive any tips
got a 6.30 am start next week, about -2 in the morning at the moment.
not too worried about me but any tips on inside and outside of windscreen vision freezing over....
only got about 50 miles to do but all M way..
Replace with aeroscreen? ;)
Put the doors and roof on, shut the vents that send warm air to your feet so all the warm air goes to the windscreen.
warm air ?
You are going to tell me now that you have no heater, aren't you? bbrr please no, not at minus 2
Heater !
Will the windscreen steam up? If the temperature is the same inside and out there shouldn't be a problem, it was -2 up here when I was out today and I had no bother.
Mark
I don't have a heater
Just make sure your head, hands and shoulders stay warm and you will be fine.
I would also put on a pair Long johns on under your trousers
I think Paul is more worried about the windscreen freezing, inside and out, rather than anything else. Putting the roof and doors on is the only way I can think to reduce the problem.
the lowest I have driven is -3 and I did not have a problem with the screen freezing.
Mind you I only went around 14 miles and it was dry.
Ok ta fingers crossed
Off to Wunoff to get a new silencer ...
I don't think a silencer will stop the windscreen freezing :)  :)
We are being nosey now, where are you going and what are you doing, it sounds like fun?
Off to Wunoff in Bradford to get a new exhaust silencer
That's an early start, drive careful. let us know how you get on
I find its often the salty crud from following other cars that, unless you have a better wiper / washer system than mine, is the problem.
Also use a chamois pad thingy soaked in neat screen de-icer on hand (if you can reach inside screen with belts on).
Otherwise, I also use Rain X Anti Fog
http://www.halfords.com/motoring/engine-oils-fluids/screenwash-de-icer/rain-x-anti-fog-200ml
Good luck, and take your time!
Dave.
