where to find this "espherical joint"
Sorry for my bad technichal english...
The rubber of this, is broken. Someone knows if I can buy the rubber cover or i need to change the whole jonit?
Is the front lower of my car. The one that links the lower wishbones with the upright.
In any case... whitch car is the donor of this??
sorry. I promise you that in spanish my question would be much more concrete...
https://www.dropbox.com/s/y82fj674c21f6k4/20160208_202955.jpg?dl=0
Creo que su Inglés es muy bueno. Lo siento que no sé la respuesta a su pregunta.
Briliant. And is that easy that seems, isn't it?
Unscrew the fixings, deatach it from the upright and change it?
Seems I don't need any press tool or so?
well. If you have not cheated and used google translator... you spanish is briliant!!
:d  :d  :d  :d  :d
Yes just 2 bolts & 1 nut on the top in the upright, you might need to put some pressure on the bottom of the ball joint to stop it spinning.
Fantastic. Definitely... westfields in general... are much better build than MK...
Maybe is not a surprise for you guys... but... I was expecting the same ****!
Thanks!!
The part number if you want to source from elsewhere is
QSJ 602S
You may need a joint splitter ( cheap to buy) to separate the ball joint from the upright
Rally design also do them for £9.50p each
I have one joint splitter... is one of the few tools that O bring with me from spain... but pretty sure that will not fit in the westfield upritghs... so... maybe is worth to buy one set also...
Many thanks!! Really fast and complete answer!!
Thanks everybody.
:down:
