Westfield SEIW race / sprint car NOW SOLD
It is time to sell my 2005 built, 2015 season Westfield SEIW race car. The car has been the subject of much development and money over the past 12 months as we prepped it for racing, and has wanted for nothing on the time that I have owned it.
It was bought originally from Terry Everall on this forum, who had previously bought it from another forum member. I had the car for sale this time last year and then decided to try racing for 12 months, I'm now hooked and looking at being able to upgrade to an International C licence early this year. As a result we're racing a Porsche Boxster S in various endurance races in 2016.
We raced the car in 2015 with Classic Sports Car Club in their Magnificent 7s series and Open Races.
It fits into Group 2 for Mag 7s. This car would be equally at home in either 750mc Sports Specials, Northern Saloon & Sports car championship or CNC Heads Sports/Saloon championship to name a few.
The car has been looked after by Solutions Racing in Brighthampton, Oxfordshire for all preparation and race support. They are available to talk about the car if needed.
So, the details are as follows -
Q plated 2005 with 2 litre Vauxhall XE red top with Coscast head.
Rebuilt in May 2015 using SBD components for 235bhp - at a cost of £7,500 (parts & labour).
Mapped to a conservative 210bhp at present
Engine has <six hours running since rebuild
SBD parts used listed at bottom of advert
DTA S40 ECU
QED dry sump
SBD bellhousing and stainless steel exhaust manifold
SBD paddle clutch
Wunoff repackable silencer
Quaife 5 speed straight cut type 9 pro box with long first gear and quickshift lever
Remote oil filter, samco hoses, oil catch tank
Oil cooler
Brise motorsport alternator
Playskool full roll cage with FIA roll cage padding
FIA rain light (not presently fitted – fog light added back on for MoT) & rain light switch
Radtec race radiator
Radtec 43l endurance fuel tank
Fuel pump
New fuel filler neck & cap
Front and rear tow straps
Red top battery
3.92 Sierra LSD
Siltech oval tube widetrack and camber adjuster plus front arb
Siltech rear arb
Westfield Gaz shocks
CAT motorsport solid grooved discs front and rear with Bremsport 4 pot calipers on front
Playskool carbon aero screen and dash
VDO gauges, including dial oil / water pressure gauge
Small M&P headlamps
2015 Westfield Cobra race seat (adjustable) for driver
Westfield unpadded race seat for passenger, spare unpadded driver seat also included
Schroth Hybrid-II H (HANS compatible) six point harness for driver
PlaySkool - five point harness for passenger
BG Developments twin bias brakes with dash adjuster
Push button starter
Momo removable steering wheel
CAT motorsport quick rack with alloy mounts
Purple body with fixed arches and black cycle wings
Extended steering column
Shortened gear lever
New FIA master switch & cut out
Plumbed in fire extinguisher
Compomotive CXR alloys 6x13 front and 8x13 rear shod with Avon ZZR tyres. These are this years main race tyres so have had five plus hours running, but will need replacing soon.
Car is currently SORN and had a fresh MoT on 30th November after the race season finished. All it needs to be used on the road is number plates. The V5 is here and in my name.
There is some cracking on the gel coat on the rear right hand side they are only superficial and we think caused by petrol being spilled when refuelling. There is a small piece of the gel coat missing from the driver’s rear wheel arch, likely caused by a stone from a gravel trap. This is a race / track car and not a garage queen.
This is a very quick car, I'm not an expert on the Speed Series Regs, but a quick look shows that it would fit into several classes.
Car is priced at a very competitive £15,000. It is available for viewing / inspection at my home in Longhope, Gloucestershire. Feel free to contact me via the forum or on 07764 176 276.
Many thanks
Rich
SBD Engine components used in 2015 rebuild -
PIST-OM87.00XS 87.00mm Omega/SBD H.T. Piston set(4) 2.0L XE(2046cc) 1.00 434.00
ROD-VX-2.0XE-143S Steel Rod VX 2.0L XE 16V (Set of 4) 143mm (55lbs torq) 1.00 754.00
HEAD-CYL-1 Head 2.0L XE/LN/Turbo (Coscast)16v GM 1.00 695.00
VLV-VX2-00-IN 2.0L 16V XE Valve Inlet 33mm H. x 7mm Stem (STD Race) 8.00 120.00
VLV-VX2-00-EX 2.0L 16V XE Valve Exhaust 29mm H. x 7mm Stem (STD Race) 8.00 120.00
VLS-05K Double Valve Springs set 16 off 1.00 179.00
VLC-7K Titanium Valve cap 2.0L XE 16v +3mm Set Solid TYPE ONLY 1.00 229.00
VLP-9K 2.0L XE 16v V-S.Platform 1mm Set 16 1.00 78.40
VLV-SS1 Valve Stem Seal 7mm STD 16.00 20.00
CMFL-2S SET-16 Cam followers Ultra Light Weight +2mm Skirt(28.10mm) 1.00 310.08
SHM-7-UGD 7mmTop Hat Unground 0.200"+ set 16 1.00 78.95
HEAD-SHIM Assemble & Shim head for solid followers 1.4-2.0L 16v 1.00 650.00
CM16V2-M278-11.78 16V XE 2.0L 278 Degrees 11.78mm 105/3.46mm 1.00 240.25
CM16V2-M269-11.42-S 16V XE 2.0L 269 Degrees 11.42mm 105/2.59mm (SHORT EXH) 1.00 240.25
GSK-VX2-C88.00-01 SBD Spec Cometic 2.0L XE H/GSK 5 Layer/.050"/88.00mm 1.00 120.50
BLT-H1 Head BLT 2.0l 16v Pre93 REQ10 (Torx Socket) 10.00 20.00
GSK7 Head Gasket Set 2.0L 16V - GM complete 1.00 80.95
BRG2 Bigend Bearing SET Narrow (19.20) L/C 2.0L STD 0.00 1.00 35.01
BRG-M1 Main Bearing 0.00 2.0L XE 16v & 8v H/Duty L/C 1.00 43.20
CRK-SF1 Oil Seal Front Crank / Oil Pump 2.0L 16V XE 1.00 14.60
CRK-SR1 Crank Rear Seal 2.0L 16V 1.00 13.40
CMB1 Cam Belt 2.0L XE Pre 93 with Round tooth (141T) 1.00 27.75
FLY-B4 Flywheel Bolt ARP H/D 2.0LXE 16v Small Head 16mm 8.00 52.16
WT-PM1 Pattern XE water pump early type round tooth 1.00 36.95
BLT-MK1 Main Cap Bolt Set Early 2.0L Heavy Duty (75mm) 1.00 10.00
VLV-COL-1 Valve collets 2.0L 16v XE 32.00 21.12
HEAD-SKIM Skim cylinder head - Up tp .010" 1.00 85.00
Nice piece of kit and originally built by Mark Anson. Always handled well and good to see the high spec of the latest mods
Blimey, Ive not seen my old car for ages. Always wondered what became of it.
Originally built from a new kit and SVA'd by me back in 2005 and competed in the Speed Series in class F fora season before I went bike engined
Pleased its continued to be used for racing and has been upgraded along the way.
Looking at the pictures a lot is as I remember it.
Good luck with the sale, would be great to see it back in the speed series.
Someone is going to get a great car.
Mark, I remember the year after I bought it seeing you at Autosport helping on the PlaySkool stand, hence why the car shortly afterwards ended up with their belts and roll cage on it!
Will be really sad to see it go, we had some tremendous races last year in it, but the longer endurance stuff is very unfriendly to these types of car. With the Boxster we'll be able to do stints of 90-120 mins.
Trailer has been removed from the sale. Car has now had all the stickers removed and has has a good clean, it is sat in the garage waiting for potential new owners to come and see it.
Nice car RichUK and good luck for the sale.
It looks to be well prepared and i'm sure a competitive car.
Mike
Provisionally sold, subject to payment.
RichUK - did the ZZR's not go off during a 40 minute race?
No, in the dry they are fantastic. We worked out we could put 1.2g through them before they break traction, even at the end of a race. Our race tyres still have life on them, after five x 40 min races plus qualifying last year.
Are they medium compound? Would like to get your advice on the CSCC Mag 7's by the way.
Yes, medium compound. More than happy to talk Mag 7s. We'll also be at all the CSCC race meetings this year if you want a natter in person.
HOPE ITS GOING TO A GOOD HOME. WOULD LOVE TO SEE IT OUT COMPETING AGAIN.
Might be doing the 750 MC sports specials now to be honest. Decisions decisions!
Drop me a line if you want to have a racing chat, always happy to talk through our experiences.
Car & trailer was picked up today, off for a career in hillclimbing. I'm looking forward to seeing it at Prescott later in the year.
