dingus120 Posted January 11, 2016 Posted January 11, 2016 Anybody out there got any of the following before I spend an arm and a leg at SBD , MBE ecu and loom ? SBD dry sump and tank ? Gen 1 throttle bodies ? . They're all upgrades I'm considering but add up to a load of cash new
XTR2Turbo Posted January 11, 2016 Posted January 11, 2016 Just as an aside .. Make sure you get the large 5 litre dry sump tank not the smaller 3.5 litre version
dingus120 Posted January 11, 2016 Author Posted January 11, 2016 I was looking at that , I've got the standard westfield tank at the moment and I'm guessing that's around five litres ?
Dave Eastwood (Gadgetman) Posted January 12, 2016 Posted January 12, 2016 SBD's 3.5 litre tank is really just for the XE. Not sure what size Westfields is, but would have thought 5 litres or more.
Trevor Little (Trevturtle) Posted January 12, 2016 Posted January 12, 2016 ecu ..but no loom here. http://forum.wscc.co.uk/forum/index.php/topic/117330-mbe-967-ecu-and-lead/
Nick Algar - Competition Secretary Posted January 12, 2016 Posted January 12, 2016 ecu ..but no loom here. http://forum.wscc.co.uk/forum/index.php/topic/117330-mbe-967-ecu-and-lead/ Sorry, but for a Busa you should really use a 9A4 ECU minimum. if going MBE 1
dingus120 Posted January 12, 2016 Author Posted January 12, 2016 It is the 9A4 ecu I was looking at getting for mine
mark.anson Posted January 12, 2016 Posted January 12, 2016 Some Gen 1 Throttle boddies on Uphill racers now for sale.
dingus120 Posted January 13, 2016 Author Posted January 13, 2016 Cheers Mark , I think they're stock bodies apart from the high flow fuel rail which I've already got , I'm looking for the SBD bodies
XTR2Turbo Posted January 13, 2016 Posted January 13, 2016 Speak with Daytuner. They have mapped loads of MBE bike engine cars. When I took my car there he didn't think changing throttle bodies materially helped output. Also speak with GWR motorsport. They would probably be cheaper for a loom and ECU. for Motec they offer 15% discount ... maybe the same for MBE Also if going to all the expense and wanting MBE I would go 9A9 so you have better launch and traction options and in the future gearbox control. Also don't overlook the new Motec M1. They have a plug and play option for the BUSA now I think. There are also people that can now map the standard bike ECU without needing power commander. You might also want to check what rotor / crank trigger your engine has. All depends what you are trying to acheive really
dingus120 Posted January 13, 2016 Author Posted January 13, 2016 Thanks for all that info , I'll do a bit more searching around before I put some cash in , I've got two engines , one standard circa 2001 which might need the rotor changing and an extreme built K7 which has been bored to 1350 flowed head and billet cams and other stuff , that should be good for a fair bit over 200bhp once set up correctly ( it's quoted as around 235bhp but I think that's a bit optimistic ? ) . That motor has the big cc nova sump on it which I've been told is a pretty good sump . SBD have tweeked their sump to relocate the pressure relief valve which helps to keep it submerged in oil and it also looks a lot neater with less plumbing needed that's why I was looking at theirs . What's controlled on the gearbox with the 9A9 ?
