Kev Bamber Posted September 29, 2002 Posted September 29, 2002 Vulcan 1700cc 135 bhp injected X-Flow, spec as follows: Emerald M3D ECU Maxiflow big valve head 234 cam HC pistons Steel rocker posts Cosworth rod bolts Toothed crank/alternator/water pump pulleys HC oil pump Shallow well baffled and sorted sump Exceptionaly well sorted, mapped and ready to run to include: ECU, loom, all sensors, throttle bodies, exhaust, starter, alternator, clutch, engine mounts, in fact everything to fit and run. Will also include brand new 244 cam & followers, the engine is built such that this is a direct fit. (rod bolts, head, springs, piston pockets etc.) £900 ! If you find more for less, buy it!! For more info, photos & detailed spec email kev.bamber@tesco.net or phone 01253 406942 (Blackpool)
SteveD Posted September 29, 2002 Posted September 29, 2002 howwwwwwwwwwwwwwwwww much only jokin kev its a bargain better hadn't let dwarf child see how cheap it is that will upset the little munchkin
