Scholar Racing 1.8 Zetec on Jenvey ITB's and MBE management.
Up for grabs is my Scholar Racing engine 1.8 silvertop Zetec
Covered just over 16,000miles
Spec is as follows-
ARP Rod bolts
Ported and polished cylinder head
Regrind piper cams
Jenvey ITBs with piper cross filter
Base manifold ported and matched to head
MBE956 ECU
Mapping lead
Race loom
Alternator and brackets
All sensors, injectors and coil
MBE is mapped to a set of Bosch injectors but one is temperamental (I will supply these injectors as they are fine for start up and to drive on to get the engine mapped), I'm supplying a set of ST170 injectors recently cleaned and flow tested but the ECU will need mapping for the ST injectors.
Estimated power is around 175bhp
This was a great engine and runs fine, No clutch, exhaust or thermostat housing supplied but with these bits sourced, you should have pretty much everything you need to get running.
£1500ono
Any questions, please give me a call on 07985266042.
FE30C6BE-CA61-4EFE-8D06-420F10BBB724_zps
2F9D0711-8899-4CB7-B15C-44075D1F3D7F_zps
53046A6B-185F-48CD-A264-1C573A387DE5_zps
B5ABEB3F-09D6-4A6B-8F89-9C6FE85303B7_zps
2779DDC5-D20A-4B10-AB6E-7703AE22F271_zps
630FD171-20F8-4A1E-A34A-C160D61B72FC_zps
I could also supply the engine with a MoTeC M800 and UTC with a Rachan DR-25 loom and all sensors for an additional £2000.00
This included fuel pressure and oil pressure monitoring
The MoTeC has been correctly mapped for the ST170 injectors
805E6410-1C93-4A85-B7F6-E1249108745A_zps
Bargain!
  • 1 month later...
PM sent.
Is the engine still available?
Thanks, Mark.
