Linds Posted October 15, 2002 Posted October 15, 2002 If you run a fuel injected engine and suffer from fuel surge then you need an improved swirl pot. The items below will solve the problem completely without needing to mod your tank. Both little used and in good condition. The low pressure pump will pump fuel from main tank to the swirl pot - keeping it topped up. The high pressure injection pump will be fed by gravity from the swirl pot. Fuel return goes to the swirl pot. SBD Swirl pot - nicely crafted in aluminium, originally cost £120, yours for £70. Facet Red Top fuel pump. In Demon Tweeks for £80ish. Yours for £40. Both together £100. **** SOLD**** Plus postage cost. Call Lindsay 07973 714363
