X/Flow spares
John Loudon - Sponsorship Liaison
Brand new uprated AP Racing clutch cover and friction plate - still boxed £100
Brand new Piper vacuumless Lucas side exit distributor with modified advance curve to max 35 degrees. New cap and rotor included but no drive gear - still boxed £35
One piece steel front pulley for X/Flow - £15
Alloy rocker cover for dry sumped X/Flow - £15
Rocker assembly with steel rocker posts for X/Flow - £20
High pressure oil pump for X/Flow, good condition - £10
X/Flow thermostat housing with rad cap filler neck (Mk1 XR2) - £10
Standard  X/Flow crank (ground to -0.010"), standard rods and standard flywheel suitable for lightening - £25 the lot
Various other X/Flow odds and sodds. Let me know if theres something your need. I might have it.
Im in Coventry
Regards,
John Loudon
07971 576848
02476 511518
jloudon@usa.net
John,
YHM
Hi John!
Do you have an alloy WET sump rocker cover going spare?
I'd like a spare one to experiment with different breather arrangements.
D'ya have any (unused!;) Xflow gaskets such as:
Big-bore exhaust
Sump (competition or cork)
Rocker cover
Inlet
Timing chain cover
Rear oil seal cover
Water pump
I'll gladly have any of the above off you.
Trust your Puma-isation's going OK :)
Gary and Studbuckle
Ive sent you both an email.
JL
