M-Tech V4 ECU ( Megasquirt ) NOW SOLD
Here is a fantastic opportunity for anyone building or converting to Zetec power !!!
Due to upgrade I am selling my well proven ( Championship Winning ) M-Tech V4 ECU ( Basically a MegaSquirt ) with Zetec 2.0 Blacktop map loaded and a full Zetec engine wiring loom, all in perfect working order.
The M-Tech V4 ECU is very similar ;) to a megasquirt  MS1 V3 and uses the same TunerStudio tuning software. This ECU will run any 4 cylinder wasted spark set up and for a Ford does NOT require the EDDIS pack as it has it's own built in coil drivers.
The TunerStudio software can be re-mapped by any tuner familiar with this software, Matt @ M-Tech in Wiltshire and Bailey Performance in Telford are just two that spring to mind. Connection to the ECU is simple via a serial lead ( + USB Serial Adapter ) and of course a PC.
The current Zetec map loaded has been tweeked for the Silver Bullets own slightly modified Zetec power plant and would need re-mapping for your particular set up, however it will be perfect as a base map to get you up and running.
The professionally made engine wiring loom will give you a Plug & Play trouble free installation for a Westfield with the ECU located under the scuttle as follows:
Crank Position Sensor -------------- 2 Pin Mini Timer Plug
Coil Pack ------------------------------- Ford Gen 2 Coil Pack Plug
Injectors -------------------------------- 2 Pin Mini Timer Plugs
TPS ( Colvern ) ----------------------- Econoseal Plug
Cylinder Head Temp Sensor ------ Std Ford 2 pin plug
Air Temp Sensor --------------------- 2 pin Mini Timer Plug
So there you have it, a complete plug & play ECU / loom Zetec powered Westfield package. New this lot would be at least £800 ( a lot more if Omex, MBE or Emerald.. I know I've just replaced it all :down:  ) available to WSCC members at an unbelievable £400.00
Martin
Bargain....
I assume this ECU can only handle normally aspirated engines then ;-)
Super charged silver bullet ?
PM sent.
Pm replied to Fozzie
Sold subject to payment & collection
SOLD
