Chris Hooper Posted November 22, 2015 Posted November 22, 2015 I'm thinking of fitting out the interior of my Westfield build. I have a carpet set already so I'm looking for interior side panels and various bits of trim and maybe seats. I'm on leave this week so I can collect if you guys have any left over bits !!! My car will be white so I'm looking for black bits. Thanks.
Chris Hooper Posted November 24, 2015 Author Posted November 24, 2015 Bumptey bump I have seats now so it's the side trim panels for a low floor SDV I need most. Thanks
Mark (smokey mow) Posted November 24, 2015 Posted November 24, 2015 Bumptey bump I have seats now so it's the side trim panels for a low floor SDV I need most. Thanks if it helps your search the interior side panels are the same regardless of whether the the car has standard or dropped floors. Also the SDV is no different to the other models. Basically any panels for a wide body should fit
Chris Hooper Posted November 24, 2015 Author Posted November 24, 2015 Cool thanks Is there a gap at the bottom ?
Mark (smokey mow) Posted November 24, 2015 Posted November 24, 2015 Mine is an early chassis with the aluminium dropped floors, with that they supplied a narrow strip of carpet to fill the gap. With the powder coated steel floors it probably doesn't show the same.
Dave Eastwood (Gadgetman) - Club Chairman Posted November 24, 2015 Posted November 24, 2015 I seem to recall my side cover panels had a drop down section that fits down into the lowered floors.
Chris Hooper Posted December 15, 2015 Author Posted December 15, 2015 Come on guys there were loads of these kicking around a couple of months ago.
Kit Car Electronics and Essex AO Posted December 15, 2015 Posted December 15, 2015 On the Westfield Parts Shop the lowered floor trim panels look quite different to the standard floor ones (and even more optimistically priced). Shame, because I have a good condition black standard floor set with only 4 rivet holes in them to sell
Mark (smokey mow) Posted December 15, 2015 Posted December 15, 2015 On the Westfield Parts Shop the lowered floor trim panels look quite different to the standard floor ones (and even more optimistically priced). Shame, because I have a good condition black standard floor set with only 4 rivet holes in them to sell there's no reason I can see why they can't be used on a dropped floor car. As I said above, Westfield use to supply a small piece of carpet to trim the side of the floor below the panels when fitting them to cars with dropped floors. Obviously they've changed the design of the panels slightly now to incorporate an extra bit that extends into the floor negating the need for the strip of carpet.
KugaWestie Posted February 17, 2016 Posted February 17, 2016 Hi Chris Are you looking for a carpet set? http://forum.wscc.co.uk/forum/index.php/topic/117870-mazda-sdv-carpet-set/#entry1240845
