Adding up to gauge interest.
12 month old and as new DTA S60.
Can be loaded with a variety of maps from my selection. Also available with software for PC
Only changing as new layout requires S80.
£700
Hi Arm, I'm interested. What wiring loom mods would I need to connect it to my Hayabusa, e.g. bespoke loom? And how do you find it on your S/C Hayabusa? does the ecu work with wideband lambda?  What's your reasons for moving up to the S80?
Cheers,
Dean
Hi
I cut the end of an existing loom and put the main connector on to match the dta. All connector plugs and crimps are available.
DTA S60 runs a Lambda input and thats how we mapped it on the dyno. I'm changing to experiment with a special ecu just because I like doing these things
It runs a treat with the s/c hayabusa and gives all you need with launch, traction, logging, lambda, can output etc.
If you are supercharging and have this ecu then you can have my s/c map. That alone save a mapping session of £500 plus a day of hard running !
I cant see anyone otherwise giving away a good busa s/c map .
A
I also run a S60 pro on my 2.0l duratec. Good piece of kit!
Sounds interesting, I don't suppose you have a standard ecu map too do you? I don't want to have to pay circa 500 to map my car for the time being.
Cheers,
Dean
Hi yes I have a Nat asp hayabusa map.
