Hi,
I have been clearing out my garage and have the following items for sale.  All from Westfield SEiW with 2.0L Pinto engine.   viz:-
Pair front vented discs 260mm x 25mm from Sierra based car.  Good condition and hardly used.  Heavy item (Approx 12Kg) so collection preferred but will post/courier to UK at purchaser's cost.  £25.
Pair front Sierra brake callipers with stainless steel brake hoses, carriers, pads, springs etc.  Callipers are reconditioned units (Delphi LC2966 etc).  Have been fitted but never run.  Slight discolouration due to storage but otherwise OK.  Carriers etc are used.  Minimal wear on pads. Heavy item (Approx 5Kg) so collection preferred but will post/courier to UK at purchaser's cost. £50.
Alternator.  Was fitted originally to car but mounting bracket (pinto) requires modification to align pulleys.  Sierra/Fiesta type PEXA68.  Good working condition.  Heavy item (Approx 5Kg) so collection preferred but will post/courier too UK at purchaser's cost.  £25.
Master Cylinder.  Standard Westfield Master Cylinder.  Not much use since new.  £65. including UK postage.
Expansion Tank.  Fiesta Mk 2 type as used originally on Westies.  Has stainless steel cover on pressure cap.  Slight internal discolouration which would probably clean up with a little attention.  £45 including UK postage.
Pair Pipercross Trumpet Socks.  Double type to fit twin DCOE Webers.  Slight oil staining present. £15 including UK postage.
Coil Cover.  Stainless steel coil cover and bracket for standard ignition coil.  Unused.  £7 including UK postage.
Westfield Gear Knob.  Westfield logo on top.  Very small nick on base. £20 including UK postage.
Westfield Badge.  Enamel Westfield badge 50mm.  Has threaded spigot on rear with nut for attachment.  Unused.  £7 including UK postage.
Camshaft.  Standard 2.0L Pinto cam with followers, studs, springs etc.  No reasonable offer refused.  Purchaser pays postage.
Photos attached.
Nickietam.
Hi,
Gear knob and badge now sold.
Nickietam
