will it stick
Will vinyl stickers stick to leather?
I would doubt it, depends on the level of adhesive you may get it to stick temporary but it won't take any wear and tear.
Indeed, or decal supplier does a 'hi-tack' material which will stick to polypropylene and withstand our pressure washer test, which is seriously sticky.
However, it wouldnt take kindly to being on a well used seat for instance!  Could you get it screen printed onto the leather directly?
Daniel
If you don't mind it being permanent, You could get the graphics company to cut you a stencil from stencil vinyl and then use leather dye onto the seat.
Mike
I will have to ask them see what they recommend cheers.
The lettering was coming away from my spare wheel cover, (vinyl) I used some upholstery glue, designed for repairing vinyl to stick it back down. Lasted less than a week!
After removing all the letters, I enquire r about getting it re-done, but every graphics company I tried said the same thing, they could paint the letters/logo on, but vinyl lettering wouldn't stick.
Don't know if my hand is steady enough for painting though!
Mike
You can then use either the wipe on or spray on leather dies and paints. Then once they're dry, peel off the vinyl mask.
