IVA Compliant Steering Wheel Required for Mazda SDV
HI There WSCC,
I am on the lookout for an IVA Compliant steering wheel for my Mazda SDV which I intend to recycle within the club post IVA.
I have a collapsible boss with the MX5 spline at the rear (MX5 shaft spline is 36 teeth, 15.5mm or 5/8" OD) and 6 threaded holes on 70mm PCD at the front to fit a Momo wheel which was salvaged from MX5 but far to big and not IVA compliant.
Does anyone have a wheel to fit the 70mm PCD collapsible boss or the complete wheel and boss assembly to fit the MX5 spline? I am happy to either purchase this from you or 'loan' it and then send on to the next pre-IVA club member (like me currently) if preferable.
Thanks in advance for any help.
ShaunD
I just got an adapter plate made then used a Westfield wheel... and still am for some reason
Do you stil have the MX5 standard wheel from the donor?
That is what I used for IVA
I did the same as dommo and made an adaptor so I could use the westfield wheel and crashpad with an MX5 boss. The alternative is as Gary suggests which is the Mk1 MX5 wheel.
Hi Gents,
Thanks for the speedy replies.
I am hoping that someone might have the standard Westfield wheel with the crashpad centre that they no longer require to get me through IVA. The Momo I have from the donor seems much too large (about 330mm diameter I think), plus its been doctored quite a bit with thick black tape etc and I am sure it would raise a few eyebrows were I to use it for my test.
I could call in at MX5 heaven and see if they have a standard MX5 wheel I guess being as they are 5 miles from my home and always very helpful with scrap parts.
Mark - I also like your idea. Perhaps I could buy the final wheel I will use with a crashpad fitted..., or as you also suggest, buy a new one Westfield and make the boss.
Hey ho - off to Houston for a week tomorrow with no time to contemplate the important things in life like finishing my SDV.
Cheers all
Shaun.
Tom is selling his iva bits as a job lot and David wanted most but not the wheel. Perhaps you could strike a deal together.
I bought an Ali disk off eBay to make an adapter plate to use the westfield wheel. I actually like it and have no plans to change it!
I bought a Mk 1 MX5 wheel off e-bay for about £20 and sold it for about the same post IVA.  There will be one out there somewhere.
Thanks Darve,
I'm afraid I don't know who Tom is. Could you put me in touch perhaps?
I'll also take a look at a Mk1 wheel on e-bay as you suggest.
Regards
Shaun.
If you buy a westy IVA wheel you will need to bin the boss as the splines won't fit the MX5 column. I removed the plate on the boss that was drilled for the IVA wheel (100mm ish pcd) and then drilled another set of holes in it for the 75mm pcd boss i was using - free adapter plate!
Thanks for the help Prawnabie, I've got the collapsible boss from the MX5 column spline but as you suggest the PCD is about 75mm so wont fit a 100mm Westfield wheel.
I was planning to manufacture one of Mark's (now world famous) PCD converter plates when the time comes.
