dombanks Posted September 3, 2015 Posted September 3, 2015 anyone got any idea roughly how much bandwidth streaming a radio station would use? I thought it wouldn't be much at all but at work the usage seems to be really high and the only thing i can think of is i tend to have a radio on a lot via my laptop or phone (absolute or radio 6) Quote
SootySport Posted September 3, 2015 Posted September 3, 2015 about 250kbt. However having it on for long periods the overall data usage does add up. Quote
corsechris Posted September 3, 2015 Posted September 3, 2015 I've got this great idea to save resources, power and bandwidth. Bear with me...it's a bit technical. You get these things called EM waves, you modulate them with the signal you want to hear, then make a thing called a 'radio receiver' that can run for hours on tiny batteries or even clockwork power generation, they are really cheap to make and never, ever crash or need to be updated or protected from viruses. I call it 'radio'. What do you think? Might it catch on?? Quote
pistonbroke Posted September 3, 2015 Posted September 3, 2015 Sound quality[edit]See also: MP2 Quality The original objectives of converting to digital transmission were to enable higher fidelity, more stations and more resistance to noise, co-channel interference and multipath than in analogue FM radio. However, the leading countries in implementing DAB on stereo radio stations use compression to such a degree that it produces lower sound quality than that received from non-mobile FM broadcasts.[citation needed] This is because of the bit rate levels being too low for the MPEG Layer 2 audio codec to provide high fidelity audio quality.[15] The BBC Research & Development department states that at least 192 kbit/s is necessary for a high fidelity stereo broadcast : “ A value of 256 kbit/s has been judged to provide a high quality stereo broadcast signal. However, a small reduction, to 224 kbit/s is often adequate, and in some cases it may be possible to accept a further reduction to 192 kbit/s, especially if redundancy in the stereo signal is exploited by a process of 'joint stereo' encoding (i.e. some sounds appearing at the centre of the stereo image need not be sent twice). At 192 kbit/s, it is relatively easy to hear imperfections in critical audio material. ” — BBC R&D White Paper WHP 061 June 2003[16] When BBC in July 2006 reduced the bit-rate of transmission of Radio 3 from 192 kbit/s to 160 kbit/s, the resulting degradation of audio quality prompted a number of complaints to the Corporation.[17] BBC later announced that following this testing of new equipment, it would resume the previous practice of transmitting Radio 3 at 192 kbit/s whenever there were no other demands on bandwidth. Despite the above a survey of DAB listeners (including mobile) has shown most find DAB to have equal or better sound quality than FM.[18] Notwithstanding the above, BBC Radio 4 has extended the periods it broadcasts programmes with a lower bit rate (80 kbit/s) and in mono in 2012, such as the Today programme, rather than 128 kbit/s and in stereo. Programmes which had traditionally been broadcast on BBC Radio 4 DAB in stereo (from 1999 to 2011), can now only be heard in the evenings in mono, even though the same programmes still go out in stereo on Radio 4 FM, Digital TV and On-Line. The BBC have issued a statement stating that stereo is still their default for BBC Radio 4 DAB, however after the Olympics, this does not appear to be the case in the evenings, making FM broadcasts (in good reception areas) superior. As very few car radios are currently fitted with DAB if the BBC switch FM off as indicated later in the decade, some listeners may be forced to receive mono broadcasts in the future, a somewhat backward step. An Audio Quality comparison of PCM, DAB, DAB+, FM and AM is available here Benefits of DAB[edit] Quote
John K Posted September 3, 2015 Posted September 3, 2015 I've got this great idea to save resources, power and bandwidth. Bear with me...it's a bit technical. You get these things called EM waves, you modulate them with the signal you want to hear, then make a thing called a 'radio receiver' that can run for hours on tiny batteries or even clockwork power generation, they are really cheap to make and never, ever crash or need to be updated or protected from viruses. I call it 'radio'. What do you think? Might it catch on?? That sounds like witchcraft... We burn folk like you at the stake round here... Where be my pitchfork..? Quote
Blatman Posted September 4, 2015 Posted September 4, 2015 Is the radio page dynamic? Does it have ads that change/scroll or whatever? Whilst the audio stream is insignificant (unless you're on very slow broadband) there may be other things happening in the background/foreground. Quote
SootySport Posted September 4, 2015 Posted September 4, 2015 I've got this great idea to save resources, power and bandwidth. Bear with me...it's a bit technical. You get these things called EM waves, you modulate them with the signal you want to hear, then make a thing called a 'radio receiver' that can run for hours on tiny batteries or even clockwork power generation, they are really cheap to make and never, ever crash or need to be updated or protected from viruses. I call it 'radio'. What do you think? Might it catch on?? I'm sold on that. However there are a few radio stations only available on the internet. DAB radios do have most of them though. Quote
dombanks Posted September 4, 2015 Author Posted September 4, 2015 unfortunately the building i work in pretty much kills all phone and radio signal dont know what these fancy em waves tomfoolery you are talking about is i used an online calculator and it recons that 128Kbps stream for 1 hr for 1 device is ~56mb so it soon ramps up an 8 hr day will be over 1/2Gb Quote
