1700cc XFlow
711M block
High Compression Pistons (these have been machined to take Stage 3 head)
Balanced Crank and Pistons Lightened Flywheel
Stage two head Ported and Gas flowed
Piper 285 cam (timed)+ Double springs
Vanderval Comp spec Bearings
HP Kent oil pump
Baffled low level Aly Sump
Twin 40s Plus K&Ns
Aldon Distributor
Luminition Ignition
Steel rocker posts
Aly Rocker cover
Fully rebuilt by Engineer
14,000 miles only
Comes with Stainless Steel 421 Exhaust manifold
Starter motor + solenoid
Lucas Sports coil
Bell housing and clutch
Engine mounts and rubbers
A ready to go package revs to 7000
£650 ONO the lot have receipts for over £2000
07715 054 772
01743 244 694
