SOLD 2004 WESTFIELD SEW FOR SALE. SOLD
ORANGE 2004 WESTFIELD SEW 6750 miles on age related P plate. Price £6850.
Located In Herefordshire. Contact petejones666 at live.com. or 01981240588 or 07887 385022
The car is currently Taxed and Insured so test drives can be given if it not chucking it down with rain.
11Months M.O.T.
The car is in excellent condition. Starts first time every time and has never let me down. Road use only NO track days.
Only two owners from new.
Correctly registered by First owner/builder as a Westfield on 02/04/2004.
I purchased on 12/02/2005 and owned/improved for last nine years.
No emissions test required at M.O.T as no emissions are recorded on log book.
BODY.
Cycle wings.
Detachable rear arches.
Westfield carbon look stone guards.
Westfield carbon look rear light clusters.
Windscreen with wipers and washers.
Heater.
Full tonneau cover including boot. zipped up middle.
Rear boot box.
RAC roll bar.
WHEELS.
TSW Hockenheim 15 inch
Tyres Falken ZE502 205/50
COCKPIT.
Stack ST8131  instrument cluster.
Carbon dash.
Cobra 7 adjustable seats.
Willans 4 point seat belts.
FIA cut out switch.
Remote push button start. (from Hawker Hunter aircraft).
Momo steering wheel, quick detachable.
Aircraft spec switches for twin fuel pumps.
ENGINE BAY.
1600 Toyota 4age twin cam with Vernier cam wheels.
New VW polo lightweight radiator.
Samco coolant hoses.
Powervamp gel battery.
Electric fan with over ride switch.
Additional wiring loom in heat shrink.
Loom protected with heat reflective wrap where required.
Filter king adjustable fuel pressure.
Oil cooler with oil stat.
Stainless braided fuel lines.
Stainless braided oil lines.
Alloy oil catch tank.
Twin compressor driven air horns.
RAW engineering supplied parts.
RAW bell housing 4age to ford type 9.
Full side exit exhaust system.
Twin 45 dellorto carbs on RAW manifold with piper foam filters
Twin cable throttle linkage.
Engine mounts.
Engine management is Omex OMEM100 3d ignition with ECU to PC connection cable, all manuals & software.
TRANSMISSION
RAW bell housing to Ford type 9 5 speed gearbox.
3.9 ratio live rear axle.
SUSPENSION.
Standard Westfield front Wishbones and Rear axle linkages.
Adjustable panhard rod.
Protech alloy shocks all round with Faulkner springs.
OTHER.
There is some nice detailing on the car eg :
All wiring is very tidy with heat shrink unlike the spaghetti seen on some.
Front brake discs bolted to hubs using cap head bolts drilled and wire locked.
Brake calipers to uprights drilled and wire locked.
Fuel lines P Clipped to chassis in transmission tunnel & cable ties used elsewhere..
DOCUMENTATION
Large folder of receipts for build parts.
Wiring diagrams for OMEM100 and bespoke part of loom.
Westfield build manual.
Omex manual and software.
I'd be revising the price if I was you - looks too cheap to me! Looks a cracker!
Dave
Dave
Thought that myself, unless you are after an ultra quick sale in which case I'm sure it won't be for sale long.
  • 2 weeks later...
Yeah, thats 1700 xflow or CVH engined money - id start it with an 8 !
Thanks for your kind comments . The car has now been sold.
