Westfield 2004 Duratec (High Spec)
Sorry to advise that the car has been withdrawn from sale. The deal that I thought I had agreed on the replacement has fallen through - gazumped!
Thanks for everyones interest.
SORRY TO RAMBLE ON BUT WANTED TO MAKE SURE I GAVE ALL THE FACTS.
Please allow me to introduce my much loved Archie a high specification Westfield (Colour - Black). Whilst very few cars are built to the standard factory specification this car is built with lots of options and upgrades hence the detailed description below to enlighten and enable those new to the world of Westfields & the wonderful WSCC to appreciate why the specification and build of this car does stand out from the ‘crowd’.
2004 Wide bodied SEIW, built with all new parts as a modular build, registered as a 2004 plate (not a Q plate). Engine supplied new by Westfield but then upgraded to current spec with machine work carried out by Scholar Engines.
Base specification:
  • SEIW with detachable rear arches, ducted nose system.
  • Full screen, unique side screens that give clearer visibility.
  • Black Pro Race 7@13 wheels & Toyo R888 tyres (205/60/13 all round)
  • Enhanced Westfield 2000s chassis with Carbon fibre interior panels.
  • Front & rear Westfield aluminium uprights.
  • JK GRP seats (much comfier than they look).
  • Ford 2.0 Duratec (240 BHP/ 189 lb/ft torque at 5800rpm)
The Car was built by Glyn, a previous Area Organiser for WSCC Club (Manchester), his 2nd Westfield car and build & has he also assisted many more in the Manchester area club. Passed SVA first time (as did his first build) and has never let me down. It is a well-known car in the WSCC club so there should be plenty of people that can vouch for both the car and myself.
Engine upgrade carried out in late 2006 (at circa 6,500 miles) - engine upgraded from the standard 187bhp to the new spec listed below, this was set up on the rolling road by Northampton Motorsport (NMS). Last checked on rolling road Motorscope (Northallerton) showing 240BHP & 189 Ib/ft of torque at 5800rpm (flywheel) Rev limit set at a comfy 7700rpm however with the strengthening work done NMS did suggest raising this to 8000 / 8200 rpm as the power was still climbing at 7700 but I stuck with it at a comfy 7700. Full suspension & geometry set up also carried out by Northampton Motorsport and re-set by Luke at Play Kool Motorsport. At 545kg full of fuel this gives near 420Bhp/Ton which is exhilarating yet tractable, reliable and smooth to drive throughout the full rev range.
Whilst this is a very high spec Westfield, it was built for road use with occasional track use, very at home & fun to drive on A & B roads or in on trackdays or sprint events.
 All previous MOT available with mileage recorded, currently covered just over 17,500 miles, 2 sets of keys, comprehensive file of all receipts, parts listings, all vehicle documentation and rolling road/engine printouts. Taxed until Feb 2016, MOT due Aug 2016.
 Chassis / Rolling Chassis upgrades
  • Rare Westfield 2000s chassis with all additional cross bracing yet with standard engine mounts – (The 2000s chassis can come with solid engine mounts with no anti-vibe mounts that is for pure race use) but I specified standard rubber engine mount set up in lieu of solid mounting of engine that would rock your teeth loose.
  • This chassis proved to be nearly 5Kg lighter than standard (proved by myself rather than hype) yet is recognised as being stiffer than standard due to extra bracing.
Chassis / Rolling Chassis upgrades (cont)
  • This 2000s Chassis comes standard with mounting bosses for full cage already welded in as part of the chassis design
  • All chassis panels are true carbon fibre (except floor pans that remain Aluminium) and are both bonded and riveted to the chassis – for clarity these are NOT carbon effect or 3m carbon sticker on Ali panels but true pre-preg carbon fibre panels supplied by Fluke Motorsport
  • Westfield supplied upgrade to Wide track front suspension – this is a much sought after upgrade and normally the first thing owners do to upgrade the standard set up.
  • Westfield supplied upgrade to Nitron shock absorbers to front & rear, these are also designed to mount upside down to reduce un-sprung weight and further improve handling
  • Westfield supplied upgrade to add front & rear anti-roll bars – giving improved handling and cornering
  • Westfield supplied upgrade to RAC roll bar with removable stays
  • Upgrade to quick ratio steering rack – supplied from Rally Design
  • Westfield supplied upgrade to Alloy Rack Mounts (steering)
  • Upgraded conversion of front top wishbones to rose joint set up – wishbone to upright connection to give improved geometry
  • Westfield supplied upgrade to Nylon Bush’s throughout suspension & wishbone mountings
  • Northampton Motorsport carried out a full suspension geometry set up inc. ride heights, corner weighing and wheel alignment.
Engine Upgrades
  • Pocketed Pistons (Standard ford pistons)
  • Piper Ultimate Road 285 cams (DUR BP285)
  • Piper double valve springs & heavy duty cap retainers
  • Piper Vernier Pulleys
  • Ported cylinder head (chambers) and both inlet and exhaust ports matched to the manifolds.
  • Heavy Duty Big End bearings
  • Full AP racing bolts to cylinder head, rods bolts, crank casing, flywheel and crank pulley
  • Crank key-wayed to timing sprocket & auxiliary pulley.
  • Raceline low line & baffled sump
  • Raceline lightweight flywheel and clutch (Hydraulic clutch so no stretching cable)
  • Raceline water rail
  • Raceline direct to head Throttle bodies
  • Raceline 90mm trumpets
  • Raceline 4-2-1 exhaust system and trackday silencer (never been turned away for noise)
  • ITG 160mm air filter
  • Addition of 13 row oiler cooler system
  • Heavy duty cooling fan (to account for extra air resistance of oil cooler)
  • Aluminium Oil catch tank
  • Oil pressure warning light systems and oil temperature gauge (temp gauge not inc in standard wiring loom / standard set up)
  • Northampton Motorsport rolling road / engine set up and engine graphs included in vehicle documents.
Transmission Upgrades
  • BGH Sporting Close ratio gearbox (bought new) with ratios specifically picked to keep in the right rev range but leave a reasonable final gear ratio.
  • 1st – 5th ratios of 2.66, 1.75, 1.26, 1.0 and 0.82
  • AP racing heavy duty clutch (hydraulic release bearing)
  • 4.1 Limited Slip Differential with Quaiffe ATB internals
  • This set up really works and even on the previous standard engine set up 187bhp, the car could match the acceleration of 230bhp cars with standard gearbox’s – now couple that with 240bhp and it really does give exhilarating performance all the way through all the gears and still pulls very strongly all the way into and through 5th gear (my first Westfield on standard engine & gearbox didn’t really have much poke in 5th from 110mph and above where as this just keeps on pulling all the way through 5th)
Braking Upgrades
  • Westfield supplied upgrade to Twin brake bias pedal set up with balance bar and twin master cylinders – enables full balance set up of front to rear brakes.
  • Westfield supplied upgrade to AP Racing 4pot front callipers
  • Westfield supplied AP Racing vented front brake disc’s
  • AP racing front brake pads
  • Westfield supplied upgrade to Golf aluminium rear brakes (more modern, lighter and reliable than standard sierra units)
  • Hawk Performance ‘Black’ rear brake pads
  • Front to rear brake lines are neatly routed through the gearbox tunnel to provide total protection – standard factory built cars see’s these run directly under the floor pan of the drivers seat which exposes them to potential damage
Body Work
  • Standard ZK bodywork
  • Removal rear wheel arches (these are newly replaced / refreshed for the sale)
  • Front arches for 205 tyres (standard are for 185 tyres)
  • Full screen / wipers and side screens
  • Ducted Nose systems – direct airflow from the radiator out the top of the nose / bonnet instead of through the engine bay, this system normally requires some additional work to remove the nose cone as the nose / internal ducting support the radiator, however I have cleverly used the standard chassis radiator mounts to self-support the internal ducting allowing the nose cone to be removed in the very same way as a standard nose and without any need to drain the system and allowing the car to be driven (if needed) without the nose cone on.
  • This car has the best of both worlds with the option to quickly (5-10 mins) to remove the scuttle c/w screen & wipers and fit a second scuttle with aero screen – this removes approx 10kg of weight and improves aero dynamics giving increased acceleration at top end. Personally and with this tourqey engine / gearbox combination I think this really only comes noticeable from around 100mph plus, below that yes it does feel faster but that’s probably more down to the more open feel of the aero set-up
 General Upgrades
  • 3” wide 4 point safety harnesses
  • Modified side screens – plastic replaced with tinted polycarbonate to give much improved visibility (and looks)
  • Carbon fibre dash and boot cover
  • Carbon kick guards (to chassis tubes in foot well)
  • Custom rear lights (using Hella light units)
  • M&P front headlights
  • All fuel & brake lines carefully run through transmission tunnel (usually exposed under the floor pan)
  • Stack 500 digital and programmable dash systems
  • Odessey lightweight Gel battery
  • Safety Battery Cut-Off switch
  • Electronic self cancelling indicators - this uses an electronic device with 3 modes / timings which sourced on a club group purchase from the United States (also operated from steering wheel)
  • FIA Master kill switch fitted.
  • Quick release steering wheel with indicator control on steering wheel – no more taking your hands off the wheel to indicate.
  • Built for ability to quickly remove scuttle and body side pods for easy access to major components.
  • Toyo R888 tyres all round.
Located in County Durham (6miles off A1), please feel free to contact myself on either simon.rossinelli@sky.com or 07952 513623 for further information. Asking price £14,995 this reflects the many upgrades and proven ability of the car. Cost to build substantially above this figure!
Good price! GLWS
Simon nnooooooo! This is a beautiful car which I jealously eyed up at Blyton, sorry to see you're selling and hope that all is ok. I was looking forward to another battle with you in the speed series!
This car is fantastic and if I could afford it,I'd buy it without hesitation. May have to think about selling some body parts!!
Basically, what Barney said.
I really liked this car, maybe you might be interested in a cheaper Westie and cash?...
Oh dear i could be in sooo much trouble now. :-)
Thanks for your kind comments - I've tried to sum up the pleasure of driving Archie - Glen really did a great job with the build.
Sorry Shaggydoo I have another project in mind so any deal needs to be 100% cash - no Westy, Wives, Children or Camels in partex.
Evening All,
Nevermind Simon, you get to keep it and play racing drivers with us all next year :-)
Yes, thats right - just need to sort out the rollbar, as mine has rosejoints at the top - will have to have a chat with Luke at Play Kool.
Probably looking to do the Anglesey weekend in October & combine it with the trackday on the Friday.
Oct Ty Croes should be good as its the new 2 lap International including the corkscrew which we have not done before
Hi Terry,
Is it the same circuit Saturday & Sunday?
Simon
I believe the plan is 2 laps of National on Sat and then 2 laps international ( new layout) on Sunday
  • 9 months later...
Don't suppose you could be tempted into putting it up for sale again could you? Sounds exactly what I am after!
Dave
