Clarke 1.25hp Bandit Air Compressor
Just want to see if anyone is interested in my 'old' compressor before I 'bay it'. Works a treat, handy compact size, 1.25hp where the new ones are only 1hp. Only selling because my son wants to start spraying at home and this just couldn't cope with the duty cycle needed for big painting projects. I've used this to rattle off wheels, tyre pressure and air blowing and the occasional epic fail spraying garden furniture...
Has no issues,no leaks, holds pressure, only thing I would say is the hose is a pain, not a fan of curly hoses so would benefit from a simple rubber hose at some point but it's good to go as it is. Pic shows the air valve handle missing, its back on!
I can't post this as its 15kg so would have to be a local pickup, I live in Atherstone North Warwickshire.
I'm looking for £65
compressor
Manual is here:
http://www.clarkeservice.co.uk/manuals/compressors/bandit.pdf
Spec is below:
Model.................................................................. BANDIT
Maximum Air Pressure ....................................... 8 BAR - 116 PSI
Air Displacement ............................................... 4.5 CFM
Motor .................................................................. 1.25 HP
Voltage ............................................................... 230 VAC 50hZ 1pH Motor Speed ...................................................... 2850RPM
Sound Power Level ............................................ 87dBL
Weight................................................................. 15 kg (unpacked)
Part Number ....................................................... 3110243
Dimensions (mm) ............................................... 425x325x460mm
Duty Cycle ......................................................... 2 min ON, 2 min OFF**
**Duty Cycle...This is in respect of the compressor motor ONLY. If the motor runs CONTINUOUSLY for more than 2 minutes, there is a danger of damage occurring. Under these circumstances, it must be switched OFF for at least a 2 minute period.
