The Duck Posted March 1, 2002 Posted March 1, 2002 Tran-X Escort Mk11 plate LSD 45/90 diff as in a SE 6 months old, 120 miles since rebuild £375 Vauxhall 16v XE Dizzy £40 Vauxhall 16v XE front Pully £20 4 Row oil cooler pipes vauxhall sand plate £50 Westfield standard top pedle box master cylinder £15 Westfield SE rear 175 lbs springs 10" £20 westfield SE rear 150 lbs srings 10" £20 Escort Mk2 rear axle no diff or shafts ready for westfield mod £40 Westfield top pedal box brake light switch £5 Westfield top rad pipe with fan temp switch £5 Brake pipe metric T witch brake ligh switch £10 Recon Cortina front calipers 2500 miles of use £40 contact mike on 07899801707 or e-mail ma@ggr.net --------------------------------------------------------------------------------
