Pair of Compomotive CXR 13" Rims ET-12 for a quick half way wide track conversion
I have a pair of Compomotive CXRs 13" x 6.0" wide with an ET-12 offset. Standard 108 PCD in black.
We tried these as a quick intermediate measure between the standard track Westfield suspension and a full wide track kit. They definitely improved the front end turn in but in the end we opted for the full Wide Track after we bent a lower wishbone.
THIS WILL REQUIRE A BIT OF ALTERATION TO YOUR FRONT CYCLE WING BRACKETS TO GET THEM OVER THE CENTRE OF THE WHEEL.
They are in great condition and could be used on the front or rear to widen the stance of your car.
A1F942F2-7C3A-404B-9669-3E58E2A55340_zps
E217449E-62E8-4568-9982-FA3B38125F7D_zps
78598279-8E2E-4EDC-9969-3722E53C47B2_zps
I do have the rest of the standard track Westfield wishbone kit in the garage if anyone needs a few wishbones for a repair.
£80 COLLECTION ONLY PLEASE
Hi were are u based for pick up
Regards James
Sorry missed that key bit of information.
Peterborough (work) or St Neots (Cambridgeshire)
Flippin bargain! Should be £80 per wheel!
  • 2 weeks later...
Anybody interested? Will stick them on eBay next week if not...
Hi Cuzzy88
Just reading into your original post, are you saying this wheel offset caused a lower standard wishbone to bend?
That would tend to put folk off IMO
My previous Westie ran 15 minilights with similar offset and I didn't have an issue with std bones
Hi Cuzzy88
I can't see where he says that! In fact, I would have thought that would be an impossibility. He says he bent a wishbone, so decided to go wide track. You couldn't really use these with wide track, unless you wanted them to stick out "a mile" from where the line of the rear wheels.
Depends how you read this....
[/b]
I agree, I can't see it bending a wishbone, as I said in my previous post, but it could be implied this offset gave a problem to him, which would put potential buyers off.
I'm sure he will come back to explain
Agree this offset plus widetrack would be excessive!
No the bent wishbone was due to an incident involving a very quick deceleration caused by a tyre barrier! The wheels were not fitted at time and are completely unmarked and straight!
I would suggest they would either be great used on the rear to increase the track or on the front with standard wishbones to increase the track/grip.
