Essex crew, its been emotional, but the lure of the fantastic Peak District roads and a decent sized garage have become too much...!
Essex I'll be off :( ...but Peak District, I'll see you all in September!! :d  :yellow-westy:
Good luck and don't forget your brolly :)
It was great to meet you Russ, good luck and I'm sure we will bump into each other at some meet or track day
Be lucky Russ,I'm sure our paths will cross at some point in the future
Im still around for a bit, here til September :d
As one of Julie's peak district posse I can say that you will be most welcome Russ!
Clearly they've caught up with you again, time to move on!
Good luck with the move, i hope you enjoyed your temporary attachment to the Essex area.
I'll probably make a meet or two before I go Pete :)
Great, September, the weather will just be turning back to dry again, look forward to seeing you.
Julie
Russ
you will have plenty of opportunity to master Cadwell
however its a long way to Martins if things go wrong
enjoy the new area
Chris
