Hi All
Have fitted a new engine in the Megabusa, after the last one expired.
It has a power comander fitted which was set up on the rolling road with the old engine by the previous owner. Do you think it's worth having it back on a rolling road now there is a new engine? The engine is the same as the old one except for having a dry sump set up this time.
Also if it is worth doing can anyone recommend a RR in Essex, if they MOTs as well that'll be a bonus.
Paul
The two steve's at track n road in rainham are good, a quick call should confirm if they do bec. As a bonus they also do evening session which can be handy - but dont be suprised if thay insist you go for a test drive when they have finished despite it being 1am!!
Could be worth a quick check over - my car (XE, rather than 'Busa) made a little extra power with a dry sump due to less windage losses, so did need a small tweak to the fuelling.
Cheers Pete, I'll give them a call tomorrow, nice and near too.
Will be interesting to see what its making compared to the original engine.
They can be a little grumpy but you get used to it and will do a proper job on your car.
