TrophyJem Posted July 6, 2015 Posted July 6, 2015 Any ideas as to where I can get a fuel pump bracket similar to the link below, but cheaper and probably made from metal? http://www.demon-tweeks.co.uk/motorsport/fuel-pump-accessories/atl-single-mount-to-suit-bosch-pump-or-filter-60mm I'm really strapped for space either side of the pump, so this sort of bracket would cure my problem. Ta
Terry Everall Posted July 6, 2015 Posted July 6, 2015 Its very simple to fabricate from a thin piece of ally
Evo,s 7SE Posted July 8, 2015 Posted July 8, 2015 use the spring clips from b and q the ones for hanging tools handles etc there springy and cheap and come in lots of different sizes
MPG Posted July 8, 2015 Posted July 8, 2015 Its very simple to fabricate from a thin piece of ally That's what I did, although I used steel because I was worried about fatigue cracking in this case. I think it was probably 18 gauge, but it might have been 22. You can find a picture here. You can't really tell from that picture, but the bolt holes are inside that rectangular region and there's a small spot weld holding the two flaps together in the center. The bit that is bent under the frame tube helps cut down on vibration.
