Minilites with new Toyo's Still available
Posted here rather than in sponsors section as they are off my personal car :
SET OF 6 K&N MINATOR WHEELS FRESHLY POWDERCOATED IN SATIN BLACK AND 4 TOYO R888'S
3 OF 6X13 , TWO HAVE NEW 185/60R13 GG R888'S FITTED
3 OF 7X13 , TWO HAVE NEW 205/60X13 GG R888'S FITTED
FRONTS ARE ET18
REARS ARE ET5(STAMPED) HOWEVER CAN SUPPLY MEASUREMENTS FOR YOU TO CHECK.
THESE HAVE NEVER SEEN THE ROAD , WILL TAKE SOME PICTURES AND POST UP SOON . I AM IN GL15 POSTCODE AREA CONTACT ME ON 07971 264550 OR PM
WHEELS ONLY ARE £300 , TYRES ONLY IS £300 JOB LOT IS £500.00 , I WON'T SELL THE TYRES UNTIL THE WHEELS HAVE SOLD .
I HAVE SOMEONE INTERESTED IN THE TYRES ALONE IF YOU JUST WANT THE WHEELS , THEY WOULD PROBABLY SUIT AN OLDER CAR WITH MORE OF A RWD FITEMENT THAN THE NEWER STUFF WHICH TENDS TO HAVE FWD OFFSETS .
Wheels%20to%20clear%20176_zpskhhu8ttz.jp
I have contacted Julian but neither of us know if they will fit my car.
My Sierra SDV SEIW is currently running 195/45/16 Toyo Proxes on TSW Avus R rims with an ET of 35.
Can anyone tell me if 13" rims with an ET of 18 will fit?
My fag packet calculations tell me there will only be a 40 mm rolling diameter difference and the offset should not be a problem under the rear arches.  The problem may be on the front where the steering arm might foul the wheel and the offset might cause a problem with the cycle wing.
My car is off the road at the moment otherwise I would drive up there and do a trial fit.
ET 18 won't fit the rears on a Sierra SDV (in my opinion) - I have et37 on my 15" rims and they are 'snug', much more would foul the arches I reckon.
However, I'd love to be proved wrong as it would give me more options in the future!
Here's a pic that shows how close it is with 7" x ET37 - another 19mm would be pushing it I think - although this is with 195/50 profile tyres, 195/45's were a little more forgiving (205s would also be tight I believe)
Chris,  Would the fact that my rims are 71/2" compared with 7" make a difference?  In other words, would I be saving 1/4" on both sides?
No idea to be honest, I'm afraid it can all depend on tyres and particular rim designs. I tried some 13's on mine and they fouled the calipers - but only because the design of the rims on the inside - another rim might have worked.
You will only really know for sure by trying a set.
The factory told me that the recommended size for the Sierra SDV was 6.5"x15 with 195/50 tyres ET 38, yet my 7" rims fit just fine - I took a chance after measuring up and was lucky I guess.
PS sorry for Hijack Julian - but I guess it is kind of related!
Chris - thanks.
Julian - I can't take a chance on buying them blind.  However, I should have my Westfield on the road in a week or so.  If they haven't gone by then, could I take a run up to you and do a trial fit?
Photos would be appreciated.
This might help you work out any clearance issues, http://www.willtheyfit.com
Good call - I used that when checking out my first set of wheels :)
Mike , I have a spare 205 tyre so can get built up on one of the rears if you want and take it back to try if you were going past / nearby , if no good post it back to me and we know for definate .
Julian, very many thanks for your patience and the offer of the wheel but the calculator tells me that the front wheels will be a problem and the cycle wings will need altering by too much or probably need changing. Good luck with the sale.
Kingster996 and Bigals - that calculator is brilliant :yes:
I have K&N Minators as track day wheels.  They are very close to the caliper on the rear (3-4mm clearance), but do fit it if you use clip on wheel weights.. stick on weights are too thick
You have PM.
  • 1 month later...
I HAVE UPDATED WHEEL RIM SIZES AND HAVE ALSO PUT A PICTURE UP
THESE ARE ALSO LISTED ON FACEBOOK PAGES TOO SO GIVE ME A SHOUT IF YOU ARE INTERESTED
I DO ALSO HAVE SOME CARBON FIBRE ENGRAVED CENTRECAPS TOO THAT WOULD ALSO BE FOR SALE THAT WOULD FIT THESE WHEELS
Wheels%20to%20clear%20176_zpskhhu8ttz.jpWheels%20to%20clear%20177_zpsol0qbfhu.jp
If the carbon centrecaps don't go with the wheels I'd be interested in them to go on a set of CXR 13" compomotives. Give me a shout if they don't sell.
Rae
