1990 Westfield SEI - 2.0 Fiat Lampredi Twin-Cam
I’m tentatively offering up my Westfield for sale – just testing the water at this stage as I don’t particularly want or need to sell up, but life priorities are starting to change a bit and I wouldn’t mind having some money in the bank rather than sat in the garage!
1990 ‘Q’ registered Westfield SEI Narrow
Engine/Box:
Fiat Lampredi 2.0 8v Twin Cam
Recently rebuilt within the past 2000 miles to the following spec:
Gas flowed 'Volumex' head with 43.5/36mm valves
Bogg Brothers R1 Carb conversion, running 160 main jets and Dynojet needles
Piper BP300 high lift 290deg 'Rally' cams
High compression 84.4mm domed pistons giving 11:1CR
Guy Croft uprated head gasket
Guy Croft 12:9 race head bolts
Guy Croft oil pump
New std size big ends
New tensioner bearing
New gasket set
Alloy velocity stacks
Pipercross air filter and custom back plate
Competition adjustable vernier pulleys
External oil cooler
Stainless steel bespoke 4-1 headers and system by PD Gough
Tuned by Torque Tune. Running circa 170bhp @ 7000rpm
Facet fuel pump
Malpassi fuel pressure regulator and filter
Fiat 5-speed ‘box
Chassis:
High ratio 2.4 rack
Avo coilover suspension front and rear
Front wide track kit
Anti roll bars front and rear
Federal RSR road-legal track tyres with very little wear
Quaife ATB Diff with LSD in Westfield alloy case
Alcon Racing front calipers - Discs and pads have loads of life left in them.
Braided brake lines
Interior & Electronics:
GRP lightweight seats
Sabelt/Westfield harnesses
Brand new alloy dash, gauges and switchgear fitted, wired and configured by NMS
Plumbed in fire extinguisher
Cut-off switch
Recent Bosch S5 battery
Aeroscreen
In terms of the history, this car was purchased by a friend of mine as a bit of an eBay special a couple of years ago. It had a lot of potential but the performance wasn’t blowing him away – an issue compounded when he dropped a grub screw down one of the carbs and then fired it up….
At this point a quick refresh became a full rebuild, carried out by a mutual friend of ours who owns a Lancia Montecarlo and knows these engines inside out. Details of the build can be found here:
I purchased this car last year having seen and been out in it several times and tracked its progress in the hands of Phil. Since purchase I have carried out the following:
Full geo setup and corner-weighting by NMS (this absolutely transformed the handling)
Oil and filter change with 10W/60 full synthetic oil
Replaced old digi-dash with a set of Westfield gauges and VDO speedo
Hand-made bare alloy dash panel
All fully wired in, configured etc by NMS. This including rewiring virtually the whole car including relays and fuse boxes. It’s a beautiful job!
New rear brake cylinders (MK2 Escort)
R1 Carbs balanced by NMS
The engine is a fantastically characterful lump – it has bags of torque low-down but when it hits cam at about 4k it really flies. I’ve never known a 4-pot to sound so good!
This isn’t an immaculate garage queen by any stretch of the imagination. It has been used as a rack and sprint car in the past I believe, so there’s no interior worth mentioning and the bodywork has its fair share of scrapes and marks (including where a timing post was mounted to the nose). In truth I have no idea of the mileage – the previous digi-dash didn’t have the odometer set up so the reading was ‘stuck’ at about 14,000. The new gauges (from BCF’s car) read about 15,500, but the general accuracy of this on a car like this doesn’t really worry me.
As part of my ongoing refresh there are a few additional bits outstanding that I will be doing if I end up keeping it:
The Avo shocks are really too short and stiff for road use. It’s OK with two people in but when lightly loaded (i.e. 10 stone of me!) it can skip around a bit on bumpy roads. My plan was to take it to Procomp for a replacement set of coilovers and associated setup which will transform its roadholding. (It does handle beautifully on track though!)
The Fiat 5-speed box crunches into 5th if you rush it. I have a spare gearbox that will be included in the sale (along with a tonneau cover, MegaJolt kit and a few other bits  have lying around to go on!)
The guys at NMS commented that the diff could use a rebuild reasonably soon.
MOT is due in about 6 weeks.
It’s a little difficult to value such an unusual westy but as it stands I’d be looking for about £6,500. Obviously I’m open to offers but to go much lower there’s really not much point in me selling 
Alternatively I’ll hang onto it, work my way through the above list and enjoy the car for another 9-10 months before re-evaluating come Spring. I’ll be home all of this weekend if anyone wants to view, and I’m doing a multi-marque sprint at Woodbridge next Sunday (21st) if anyone local wants to pop along.
Located just south of Oxford. Contact via PM on here or 07850754455.
Any comments/queries/offers (!) welcome :)
The silence in here is deafening ;)
I'm going to withdraw from sale for now. Plenty to keep me occupied still :)
smart car and good advert - GLWS
Cheers Alex. Too good by the looks of things, I've persuaded myself to keep it  :laugh:
Hurrah !
