Gsxr 1000 throttle bodies. Spaced for duratec.
As title Gsxr 1000 throttle bodies. They have been spaced to suit a duratec, the injector ports have been blanked off aswell as the secondary butterflies being removed.
Only selling them as I've decided to use a single throttle body with my turbo. The manifold pictured is not included in the sale. More pictures can be sent
Located in Tamworth. Looking for £100 + postage.
would these work with a DanST manifold for a mx5 head?
I don't recall the spacing of the mx5 ports, they will work with a danst manifold as that is one pictured but you will need to alter the spacers between the throttles to suit the spacing of the mx5.
Mike
Am I right in thinking these split into four rather than 2?
Yes that's correct. They are 4 individual not 2 pairs.
Will you take £100 posted?
I'd prefer to hold out for the full price for a while, I've got them listed at £120 elsewhere. I think they're worth it.
Mike
ok, first dibs at £100
will PM later if that's OK, as at work at the moment
No problem.
Out of interest what's the diameter of the 1000s?
42mm at the manifold end - 50mm at the filter
As chris said, they taper from 50mm to 42mm.
Mike
