MWMSport Posted May 30, 2015 Posted May 30, 2015 Hi guys. I'm not really sure what this is worth so looking for some guidelines in value, this will 100% be up for sale this winter but maybe sooner if the sale will cover the commissioning of my new engine. 1.8 Scholar Race Engines zetec. Has ARP rod bolts, ported head and upgraded camshafts. It's fitted with recently balanced Jenvey ITBs with filter and a Westfield exhaust manifold. It has covered 16,000 miles. It has recently been compression tested for health and all cyclinders are within 5psi of each other around the 210psi mark per cylinders. It will come with all sensors, injectors, coil Ect. The Loom is a Motorsport grade Loom from MBE. Engine managment is MBE956e. It was recently maped by Northampton Motorsport. I have the password to the map and the mapping lead also included. The engine is still is the car so any potential buyer can see it run and drive. Bar the water pipes and the odd few bits there should be everything you need to fit this straight into your Westfield and have it up and running. At the moment I'm just looking for guideline value but will listen to serious offers.
Onliest Smeg David Posted May 30, 2015 Posted May 30, 2015 What bhp running at, blacktop/silvertop, also pic of dyno print out may help peeps.
Onliest Smeg David Posted June 1, 2015 Posted June 1, 2015 That's a great engine for a Westfield, IMO with nice amount of power for mainly road with bit of track use.
