Chris Hooper Posted May 20, 2015 Share Posted May 20, 2015 I'm building the front suspension I can't find in the book when to fit the front coil overs so I'm dong it now. The passenger side bolt will go through from the front but there is not enough clearance on the drivers side so I've fed the bolt in from the back I hope that's okay I suppose it will have to be as I can't see another way of doing it. Also AAMOI the WF supplied nut for the top bal joint is the correct size but the wrong pitch so I've emailed them for advice. Quote Link to comment Share on other sites More sharing options...
Mooch Posted May 21, 2015 Share Posted May 21, 2015 Mine both go in from the back, nut at the front. Not a problem, Chris. I don't recall a problem with the top ball joint nut but I'm sure WF will provide the right one if you ask them. 1 Quote Link to comment Share on other sites More sharing options...
Chris Hooper Posted May 21, 2015 Author Share Posted May 21, 2015 I emailed WF and they said they would post out the correct nuts this evening. So far I can't fault WF. Quote Link to comment Share on other sites More sharing options...
Chris Hooper Posted May 22, 2015 Author Share Posted May 22, 2015 Received the replacement nuts this morning. I still think there wrong. https://flic.kr/p/srWGPo You can see how they are cutting the thread on the ball joint. They will only turn a couple of times and I don't want to damage the ball joint. What do you lot think ? Thanks Quote Link to comment Share on other sites More sharing options...
Andy (Sycho) Posted May 23, 2015 Share Posted May 23, 2015 They shouldn't be tight mine just spun up & down, I would give them a call they are open today. Quote Link to comment Share on other sites More sharing options...
Dommo Posted May 23, 2015 Share Posted May 23, 2015 Checking my build thread I also had the same problem with the nuts being the wrong thread. Quote Link to comment Share on other sites More sharing options...
