MBE956e ECU, Loom, mapping lead and some sensors.
Taken from a 1800 Zetec Westfield on ITBs
Up for sale is my MBE956e ECU with full loom and all sensors except for CPS & TPS.
It can currently be seen working on the car will all sensors working. I have the pin code for the ECU so the current map can be tweaked to suit your needs.
Reason for sale is upgrading the ECU to MoTeC M800.
6D73649F-84B0-4AA7-9035-3967E660FE34_zps
As far as cost goes, I'm not really sure what it's worth. With your own CPS & TPS there is everything there that you need to get it working on your Westfield. The PIN number is present for the ECU so the map can be tweaked rather than starting a fresh with and the current map is good on my engine. (Obviously engines and specs differ so I would recommend IT to be re calibrated).
£450.00 seems a good starting point.
