Hi all
Cumulative wisdom please! I'm looking to buy a cordless impact driver, I know you get what you pay for but I don't want to spend a fortune. Has anyone had any experience of this or have a recommendation around a similar price point?
http://www.amazon.co.uk/gp/aw/d/B007IUKVYA/ref=mp_s_a_1_1?qid=1428247226&sr=8-1π=SL75&keywords=silverline+impact+driver
Barny
Sounds a bit weedy to me? 90 NM is only 65 ft lbs...
It's a screwdriver. OK for a bit of DIY; all the positive reviews talk of using it on small to medium size screws into plasterboard - which it just barely has the battery life for. Medium or larger screws into something harder like wood(!) and it starts to struggle...
I've used a Makita equivalent putting up brackets and so on into rawl plugged holes and they're handy; much more welly than a traditional electric screwdriver, but small and light when trying to get it into confined spaces.
FWIW, the impact wrenches that I've seen used for automotive stuff that have been any good have generally been at least 18 Volt.
Barney
I have a new / unused going spare. Yours for beer money.  You may need to buy a new battery though but cheap on ebay.
I can bring Thursday if interested.
David
Impact 'wrenches' have 1/2 (?) inch sq socket drive and aren't cheap!
Impact drivers may be OK for light work if bolts loosened and tightened manually.
I've a Makita li-ion impact driver and it's brilliant, but of course not cheap. IIRC it was the guts of £300 with 2 batteries (which are actually the expensive bits, costing about £90 I think)
Thanks all, advice of the wizened steering me clear of a duff purchase again! I thought 90nm would be ok for wheel nuts as I'd follow it up with a check on the torque wrench, but from what you've all said this is too weedy for the job.
Barney
David
David - yes I'll take you up on that please, see you on Thursday :d
I used to use a Snap On one - expensive but can undo any wheel nut. Most impressive was it undone caliper bolts on a 67 Vw bus - I couldn't even budge it with a long socket bar!!
Bloomin expensive though circa £350.
If you just want it for wheel nuts and will check with a torque wrench anyway, I would buy a cheap cordless drill. plenty around for circa £30 ish. Its what I use
  • 2 weeks later...
I use the Sealey impact gun which is great
The one I have as well, Just good enough for wheel nuts on a Westfield.
320NM Torque!!!!
320NM Torque!!!!
I think yours is a bit better than mine then.   15volt and 3 years old now.
I have a sealy cordless with apparently 325lb of torque it does need old wheel nuts cracked first but for reassembly of stuff it's awesome. Oh yeh and I'm a sucker for the clack clack noise when it's done stuff up. Sorry
