I have a 2007 Seat Toledo with a 6 speed DSG gearbox which I fear is failing  :cry:  :cry:
What reading I've done thus far suggests that the problem is the Mechatronic unit.  It's only just started but occasionally the gearbox sticks in 2nd, 3rd, or 4th.  Engine revs more than usual so I knock it into 'manual' and change it that way.  Mechanically I think it's fine but I guess some sensor or software is playing up.
So what do I do?  Get a diagnosis from a main dealer (at a price) and hope they are right??  Is the diagnostic equipment 'main dealer' only or what?  I think changing the unit is relatively straightforward.  Anyone know for sure??
Lookng forward to you advice - thanks.
You could try and locate an independent VAG specialist, there are plenty about, the ones I've come across tend to have ex VAG staff but charge considerably less.
martin
I use Hammerton motors on the A59 ...good guys
Mechatronics failures are not so common now but clutch pack failures are starting to rear their heads now, both have similar symptoms. There's a specialist who can repair the mechatronics.
Get it diagnosed properly but a specialist who won't just try the "swap parts out at your expense till it fixes it" approach...
Have a look at the VAG forums (Seat, Skoda, Audi &. VW) Their diagnostic systems will all be the same. There will be a list of VAG specialists in their sponsors forum,who can do just as good a job as a main dealer., hopefully one will be near you.  The mechatronic box of tricks is about £1400 so you need to get it done right.
You need VAGCOM and a lead to connect to the car to see if any codes, search the forums for info and ebay for the cable/software.
I've got a full VCDS lead which would work, you have to be careful, around 2004 they require a certain lead, most of the chepa ones on ebay dont work very well, so take a look round
http://www.mk5golfgti.co.uk/forum/index.php/topic,88875.0.html
https://maps.google.co.uk/maps/ms?msid=209732397261666218585.0004c66cecde3f435ecb4&msa=0
http://www.vagoc.co.uk/vb/showthread.php?t=122
For someone who can read the codes for you :)
PR motors in Harrogate are ex VAG guys but quite a while ago now so not sure what they know about DSG
They are at the bottom of Skipton Rd near Pets at home
Or try Autosparks for Diagnostic. Gary Green on 01423 506133 (mention my name as old pal)
Told me it was probably software. Settings have been changed as experience of age/mileage accrues.  Car booked into local dealer for a full (£96!!) diagnostic check
Fingers crossed.
  • 2 weeks later...
...and fixed!
£144 all in  :)
But having said that how long does it take to connect up a laptop and then download updated software.  Costs nothing for my phone and just a couple of minutes of my time!
If you need a genuine VAG lead again give me a shout, I have one. Same goes for anyone else!
It's easy to use and the software is free to download.
