DodgeT Posted October 24, 2003 Posted October 24, 2003 exhaust manifold, ecu, distributor, any body got any of these bits
DodgeT Posted October 24, 2003 Author Posted October 24, 2003 oops me daily drive turned only car, that be the peugeot
SteveD Posted October 25, 2003 Posted October 25, 2003 errrr no then now if you were talking westy well thats different
Rob Navin Posted October 26, 2003 Posted October 26, 2003 Dodge CCC did this conversion as part of an article a while ago. The parts for the conversion are listed as being from Neil Brogden at SMI in Oxfordshire. Kit was quoted at £500 but not sure what it included If you want any other info let me know and I will have a look through the back issues to tey and find contact numbers ect. Cheers Rob
DodgeT Posted October 27, 2003 Author Posted October 27, 2003 rob, if its no bother, the info would be interesting
Rob Navin Posted October 28, 2003 Posted October 28, 2003 The following is the highlights of the various articles on the build of the CCC conversion. SMI provided a conversion pack for a quoted price of £500. Although a total list is not provided it seems to cover the following. An uprated bush for the lower engine mount. An alloy housing for the 205 distributer. ( Allows you to use the 205 loom and management which is claimed not to have any loss of power. ) HT leads to conect the 205 dizzy. special induction hose kit to tangle past the batery position. there may be more but not listed. All the 205 ancilleries were reused. A new manifold from Janspeed was used as the Mi16 one hits the bulkhead. Running the 205 standard injection means using a bespoke inlet manifold to fit in the engine bay. Made by cutting the Mi16 unit down by two and a half inches. The whole conversion sits on the original 205 mounts using the original Mi16 brackets. It does sit a lot steeper in the bay that the original engine. The contact details for SMI are. Neil or Dave on 01295 810281 I'm not sure if you can still get back issues of CCC but most of the info was in the November 02 issue. If you can't get a copy drop me your address on a pm and I will post you my copy out. HTH Rob
